Delete VSG from VNMC
Patrick Colbeck
Level 3
Level 3
I have half installed a VSG ie I have got it so far as registering with VNMC but need to change its hostname and enable NTP on it.
If I delete teh agent config the VSG and make teh changes then renable the agent VNMC just changes everything back !
So I want to delete the VSG from from VNMC and add it back but cannot see away to do this.
Under
administration -> service registry -> clients
it shows up but the delete button is greyed out.
Any ideas ?
Pat
Patrick Colbeck
Level 3
Level 3
Forget it. I deleted the VSG VM in vCenter then it let me delete it from VNMC.
It seems VNMC rennames any VSG to "VSG" whatever the hostname is set to.
