11-28-2018 03:33 AM
Hi all,
can someone tell me what is the difference between N2K-C2348TQ-E and N2K-C2348TQ extender module? The only info I got is that E series is cheaper, but that is it..
Robert
Solved! Go to Solution.
12-05-2018 10:06 PM
Hello Robert,
The N2348TQ-E is a cost optimised version of the N2348TQ, otherwise identical in features. Internally, the -E has a different PHY. No functional differences in the specs (memory, buffers, etc).
Best Regards,
Santhosh
11-28-2018 03:01 PM
12-05-2018 07:36 PM
Hello Robert,
Please find the below picture, they are in capacity the same, so this is a cost relevant because the E model is cheaper.
Hopefully this helps, keep us posted if you have any other question,
Please rate all helpful posts, and mark as correct if this answered your question,
David Castro,
12-05-2018 10:06 PM
Hello Robert,
Best Regards,
Santhosh
04-26-2019 12:55 AM
