Environment power output nexus 3k
networkcheff
N3064X-28E-1# show environment power input
Power Supply Input:
PS Voltage Current Power Status
(Volt) (Amp) (Watt)
1 203.50 0.38 76.31 ok
2 -- -- -- fail/shutdown
Total: 76.31
Power Supply:
Voltage: 12 Volts
PS Model Input Power Current Status
Type (Watts) (Amps)
1 N2200-PAC-400W AC 396.00 33.00 ok
2 -- -- -- -- fail/not-powered-up
Mod Model Power Current Power Current Status
Requested Requested Allocated Allocated
(Watts) (Amps) (Watts) (Amps)
1 N3K-C3064PQ-10GX-SUP 349.20 29.10 349.20 29.10 powered-
up
Power Usage Summary:
Power Supply redundancy mode: Redundant
Power Supply redundancy operational mode: Non-redundant
Total Power Capacity 396.00 W
Power reserved for Supervisor(s) 349.20 W
Power currently used by Modules 0.00 W
Total Power Available 46.80 W
N3064X-28E-1#
Can someone help me why my input is so less and output of "show env power" shows 349.20w
If you found my answer to be useful please do not hesitate click on the Star button and answered.
shaps
Level 3
Level 3
The power show in the output is the amount of wattage that the remaing PSU is rated at, the power available is what is left after all the normal functions of the switch are powered up.
