ERROR: [VMWARE-VIM] Extension key was not registered before its use.
mhasabal
Hello All
ran to the issue while trying to connect to the vcenter:
boot kickstart bootflash:/nexus-1000v-kickstart-mz.4.0.4.SV1.3.bin sup-1
boot system bootflash:/nexus-1000v-mz.4.0.4.SV1.3.bin sup-1
boot kickstart bootflash:/nexus-1000v-kickstart-mz.4.0.4.SV1.3.bin sup-2
boot system bootflash:/nexus-1000v-mz.4.0.4.SV1.3.bin sup-2
version 4.0(4)SV1(3)
username admin password 5 $1$jMe7RLHo$4mZty6nJu1S8ttp/aVo3I/  role network-admin
ssh key rsa 2048
ip domain-lookup
ip host N1000vUCS 10.1.4.20
kernel core target 0.0.0.0
kernel core limit 1
system default switchport
snmp-server user admin network-admin auth md5 0x98a5eb422ff1995ab6f804e37f11bdcd priv 0x98a5eb422ff1995ab6f804e37f11bdcd localizedke
y
snmp-server enable traps license
vrf context management
  ip route 0.0.0.0/0 10.1.4.1
hostname N1000vUCS
vlan 1
vdc N1000vUCS id 1
  limit-resource vlan minimum 16 maximum 513
  limit-resource monitor-session minimum 0 maximum 64
  limit-resource vrf minimum 16 maximum 8192
  limit-resource port-channel minimum 0 maximum 256
  limit-resource u4route-mem minimum 32 maximum 80
  limit-resource u6route-mem minimum 16 maximum 48
interface mgmt0
  ip address 10.1.4.20/24
interface control0
svs-domain
  domain id 1
  control vlan 4
  packet vlan 4
  svs mode L2
svs connection vcenter
  protocol vmware-vim
  remote ip address 10.1.4.29 port 80
  vmware dvs datacenter-name NY
thanks in advance
lwatta
You need to download and register the extension key into vCenter.
This is described in the Getting Started Guide.
http://www.cisco.com/en/US/docs/switches/datacenter/nexus1000/sw/4_0_4_s_v_1_3/getting_started/configuration/guide/n1000v_gsg.pdf
Also please check out the FAQ. It has some suggestions on what to do when you cannot connect to vCenter.
https://communities.cisco.com/docs/DOC-14464
louis
