07-02-2009 05:15 AM
Hi there,
we get the error message "A specified parameter was not correct, spec.connectionCookie" when we try to add or remove a physical adapter from the port groups.
Any idea what goes wrong.
Tom
08-11-2009 03:45 PM
Tom,
I am asking our engineering team to take a look and reply to your question. I am not finding an answer in our troubleshooting guide.
pf
08-12-2009 01:14 AM
when adding multiple physical interfaces after each other, please make sure that the task for the first interface completes in vCenter before starting the second one. There is a bug in vCenter which prevents the concurrent operation on adding physical interfaces.
The same applies if these interfaces are accross multiple hosts. So when adding multiple hosts, you also have to wait until the first one is successfully added.
Could this be the problem?
Hope this helps.
Chris
08-12-2009 02:35 PM
Got a response from vmware regarding the error.
"vSphere Client is specifying spec.connectionCookie which does not match with one in the port. In the future release vCenter will ignore this value and not throw any exception."
thanks,
Roshan
10-01-2009 08:58 AM
So How do I fix it now? I need to Remove a Host From the DVS but I can't do it if I can't remove the Nic...
10-01-2009 09:49 AM
10-02-2009 04:14 PM
Sam,
You can remove a NIC forcefully from the command line of the host.
1. First list the DV ports in use:
esxcfg-vswitch -l | more
2. Find the vmnic & associated DVPort ID for that vmnic.
3. You can then remove it by (assuming you want to remove "vmnic1" with DVPort ID "100"):
esxcfg-vswitch -Q vmnic1 -V 100 <DVS Switch Name>
Robert
