Error when try to connect N1000 to VC
harry.yang84
Hi guys,
I got an error when i try to establish svs connection between n1000 and vc.
n1000v-test(config-svs-conn)# show svs connections
connection VC:
    ip address: 10.0.0.166
    protocol: vmware-vim https
    datacenter name: Calgary
    DVS uuid: -
    config status: Disabled
    operational status: Disconnected
n1000v-test(config-svs-conn)# connect
ERROR: [VMWARE-VIM] Cannot complete client certificate validation.
I was able to register the n1000 plug-in, no problem...
any idea?
Harry
7 Replies 7
sudutha
Hi Harry,
Can you please execute the command "show vms internal event-history errors" on VSM and get the ouptut? And also can you let us know the versions of the VSM, vSphere client and the vCenter Server that you are running?
Sundeep
Hi Sundeep,
Thanks for the prompt replp, and here is the output i get from event-history errors:
1) Event:E_DEBUG, length:132, at 666413 usecs after Wed Jun  3 21:33:04 2009
    [102] convert_soap_fault_to_err(1175): SOAP 1.1 fault: "":ServerFaultCode [V
2) Event:E_DEBUG, length:72, at 189812 usecs after Wed Jun  3 21:32:51 2009
    [102] vms_print_conn_info_cli(383):  Failed to read the DVS UUID from pss
3) Event:E_DEBUG, length:132, at 497442 usecs after Wed Jun  3 21:18:45 2009
4) Event:E_DEBUG, length:72, at 345235 usecs after Wed Jun  3 21:12:27 2009
5) Event:E_DEBUG, length:132, at 850579 usecs after Wed Jun  3 21:11:29 2009
6) Event:E_DEBUG, length:132, at 925866 usecs after Wed Jun  3 21:11:20 2009
7) Event:E_DEBUG, length:72, at 661187 usecs after Wed Jun  3 21:06:54 2009
8) Event:E_DEBUG, length:116, at 760594 usecs after Wed May 27 13:42:38 2009
    [102] vms_get_subject_from_certificate(2215): unable to open /bootflash/cisc
o_nexus_1000v_certificate.pem for reading
Version of n1000:
     Software
  loader:    version 1.2(2) [last: image booted through mgmt0]
  kickstart: version 4.0(1) [build 4.0(1a)S1(0.149)]
  system:    version 4.0(1) [build 4.0(1a)S1(0.149)]
  kickstart image file is: [not present on supervisor]
  kickstart compile time:  11/19/2008 1:00:00
  system image file is:    bootflash:/nexus-1000v-mz.4.0.1a.S1.0.149.bin
  system compile time:     11/19/2008 1:00:00 [01/27/2009 09:45:34]
Version of VC:
version 4.0.0 build 162856
Version of VSphere
Version of ESX host
4.0.0, 164009
Thanks for the support, i really appreciate this.
Harry
Hi Harry
Looks like you have the Beta version of VSM ( bootflash:/nexus-1000v-mz.4.0.1a.S1.0.149.bin).Go ahead and download the FCS version of VSM (nexus-1000v-mz.4.0.4.SV1.1.bin) and you should be all set.The one which you have is not comaptible with the ESX/VC build 164009/162856.
Let us know if you still have issues connecting to the VC.
Deepak
Thanks for the information.
Do I need to purchase a prod license to download 4.0.4? or it is something that I can download for free?
do you happen to have a link for that image???
You can download the 60-day Eval license from the below link:
http://www.cisco.com/en/US/products/ps9902/index.html
Deepak
this is fantastic!!
Thanks a lot guys.
Hello sudutha
i got the same error but i am running the latest version
N1000vUCS# sh ver
Cisco Nexus Operating System (NX-OS) Software
TAC support: http://www.cisco.com/tac
Copyright (c) 2002-2010, Cisco Systems, Inc. All rights reserved.
The copyrights to certain works contained in this software are
owned by other third parties and used and distributed under
license. Certain components of this software are licensed under
the GNU General Public License (GPL) version 2.0 or the GNU
Lesser General Public License (LGPL) Version 2.1. A copy of each
such license is available at
http://www.opensource.org/licenses/gpl-2.0.php and
http://www.opensource.org/licenses/lgpl-2.1.php
Software
  loader:    version unavailable [last: image booted through mgmt0]
  kickstart: version 4.0(4)SV1(3)
  system:    version 4.0(4)SV1(3)
  kickstart compile time:  4/26/2010 16:00:00
  system image file is:    bootflash:/nexus-1000v-mz.4.0.4.SV1.3.bin
  system compile time:     4/26/2010 16:00:00 [04/27/2010 10:21:17]
Hardware
  Cisco Nexus 1000V Chassis ("Virtual Supervisor Module")
  Intel(R) Xeon(R) CPU         with 2075028 kB of memory.
  Processor Board ID T5056AA2935
  Device name: N1000vUCS
  bootflash:    1557496 kB
Kernel uptime is 0 day(s), 2 hour(s), 4 minute(s), 43 second(s)
plugin
  Core Plugin, Ethernet Plugin
N1000vUCS# sh run
username admin password 5 $1$jMe7RLHo$4mZty6nJu1S8ttp/aVo3I/  role network-admin
ssh key rsa 2048
ip domain-lookup
ip host N1000vUCS 10.1.4.20
kernel core target 0.0.0.0
kernel core limit 1
system default switchport
snmp-server user admin network-admin auth md5 0x98a5eb422ff1995ab6f804e37f11bdcd priv 0x98a5eb422ff1995ab6f804e37f11bdcd localizedke
y
snmp-server enable traps license
vrf context management
  ip route 0.0.0.0/0 10.1.4.1
hostname N1000vUCS
vlan 1
vdc N1000vUCS id 1
  limit-resource vlan minimum 16 maximum 513
  limit-resource monitor-session minimum 0 maximum 64
  limit-resource vrf minimum 16 maximum 8192
  limit-resource port-channel minimum 0 maximum 256
  limit-resource u4route-mem minimum 32 maximum 80
  limit-resource u6route-mem minimum 16 maximum 48
interface mgmt0
  ip address 10.1.4.20/24
interface control0
boot kickstart bootflash:/nexus-1000v-kickstart-mz.4.0.4.SV1.3.bin sup-1
boot system bootflash:/nexus-1000v-mz.4.0.4.SV1.3.bin sup-1
boot kickstart bootflash:/nexus-1000v-kickstart-mz.4.0.4.SV1.3.bin sup-2
boot system bootflash:/nexus-1000v-mz.4.0.4.SV1.3.bin sup-2
svs-domain
  domain id 1
  control vlan 4
  packet vlan 4
  svs mode L2
svs connection vcenter
  protocol vmware-vim
  remote ip address 10.1.4.29 port 80
  vmware dvs datacenter-name NY
N1000vUCS# show vms internal event-history error
1) Event:E_DEBUG, length:134, at 121616 usecs after Thu Apr 26 23:23:46 2001
    [102] convert_soap_fault_to_err(1453): SOAP 1.1 fault: "":ServerFaultCode [VMWARE-VIM] Extension key was not registered before i
ts use.
thank you
