I am dealing with very strange issue but wanted to check with experts if i am doing anything stupid or not. I have small size EVPN+VxLAN clos network (OSFP+iBGP+Multicast+Arp-suppression (no anycastgateway) is in my setup) very standard configuration. My leafs in vPC for redendency. My leafs connected to HP c7000 bladecenter switch 6120XG.
Problem: On blade server i have two 10G nic (nic1 connected to blade-switch-A and nic2 connected to blade-switch-B) so i have configured bonding active-backup because 6120XG doesn't support MLAG. Everything working great at this point. I have Linux PXE kickstart server and i have dedicated VLAN 70 for PXE which i have untagged on 6120XG switch (because PXE doesn't support VLAN tagging). when i reboot blade server and go to PXE boot to kickstart i can see my PXE get ip address from DHCP but after that it stopped pinging that IP and kickstart failing saying no network connection (in short i can't ping that pxe IP).
I have all my VLAN/VNI configured for arp-suppression. if i remove arp-suppression for PXE VLAN/VNI then everything works, PXE successfully able to kickstart my all servers but as soon as i add arp-suppression it stopped working. Any idea how EVPN+VxLAN handle untagged VLANs?
Leaf NVE1 interface config
interface nve1 no shutdown description ** VTEP/NVE Interface ** host-reachability protocol bgp source-interface loopback1 member vni 10064 suppress-arp mcast-group 239.1.1.1 member vni 10065 suppress-arp mcast-group 239.1.1.1 member vni 10070 suppress-arp <---------- if i remove this it then PXE works. mcast-group 239.1.1.1 member vni 10100 suppress-arp mcast-group 239.1.1.1 member vni 10555 associate-vrf
Bladecenter switch untagged VLAN 70
vlan 70 name "pxe" untagged 1-16 tagged Trk1 no ip address exit
After debugging i found as soon as PXE boot load start loading CentOS linux at specific place where Linux set VLAN ID 0 on interface to make it native to allow access of all VLAN at that point i have noticed it flood my network with ARP broadcast on that specific VLAN and that cause packet loss on network and my installation stuck.
Look like this untagged frame getting in loop because of arp suppression not sure why. I do have other VLAN also and they are all tagged with VLAN which is working fine without any issue. I haven't seen any issue on them.
[root@pxe-server ~]# tcpdump -i bond0.70 -nn not port 22 and host 10.70.0.112 tcpdump: verbose output suppressed, use -v or -vv for full protocol decode listening on bond0.70, link-type EN10MB (Ethernet), capture size 262144 bytes 13:13:23.115377 ARP, Request who-has 10.70.0.112 (ff:ff:ff:ff:ff:ff) tell 0.0.0.0, length 46 13:13:23.115539 ARP, Request who-has 10.70.0.112 (ff:ff:ff:ff:ff:ff) tell 0.0.0.0, length 46 13:13:23.115974 ARP, Request who-has 10.70.0.112 (ff:ff:ff:ff:ff:ff) tell 0.0.0.0, length 46 13:13:23.116110 ARP, Request who-has 10.70.0.112 (ff:ff:ff:ff:ff:ff) tell 0.0.0.0, length 46 13:13:23.215306 ARP, Request who-has 10.70.0.112 (ff:ff:ff:ff:ff:ff) tell 0.0.0.0, length 46 13:13:23.215312 ARP, Request who-has 10.70.0.112 (ff:ff:ff:ff:ff:ff) tell 0.0.0.0, length 46 13:13:23.215823 ARP, Request who-has 10.70.0.112 (ff:ff:ff:ff:ff:ff) tell 0.0.0.0, length 46
Only way to break this broadcast storm is to remove suppress-arp option from VLAN 70. I think it could be a big in Cisco software because not sure what is the relation of arp with non-tagged frame.
This is my Leaf-1-1 config and Leaf-1-2 is second vPC peer which has pretty similar config. Its very simple network not fancy stuff, I have only 2 vPC pair Leaf as per diagram.
Question: I have enabled suppress-arp on VNI which is pure L2VNI it doesn't have anycast-gateway because my Cisco ASA is gateway for all VLAN. (I am assuming suppress-arp does with L2VNI only without Distributed gateway)
leaf-1-1# show run cfs eth distribute nv overlay evpn feature ospf feature bgp feature pim feature fabric forwarding feature interface-vlan feature vn-segment-vlan-based feature lacp feature vpc feature nv overlay ip domain-lookup system qos service-policy type network-qos jumboframes fabric forwarding anycast-gateway-mac 0000.dead.beef ip pim rp-address 10.255.0.123 group-list 239.0.0.0/8 ip pim ssm range 232.0.0.0/8 vlan 1,64-68,70,100,444,555 vlan 64 name inside vlan 65 vn-segment 10065 vlan 66 vn-segment 10066 vlan 67 vn-segment 10067 vlan 68 vn-segment 10068 vlan 70 name pxe_boot vn-segment 10070 vlan 100 name public vn-segment 10100 vlan 444 name BACKUP_VLAN_ROUTING_VPC vlan 555 name L3VNI vn-segment 10555 spanning-tree port type edge bpduguard default spanning-tree loopguard default spanning-tree vlan 64-68,70,100,555 priority 8192 route-map DIRECT-PERMIT-ALL permit 10 description ** Route-Map for BGP to redist route ** vrf context CUST1 vni 10555 rd auto address-family ipv4 unicast route-target both auto route-target both auto evpn vrf context management ip route 0.0.0.0/0 172.30.0.1 hardware access-list tcam region vacl 0 hardware access-list tcam region arp-ether 256 vpc domain 1 peer-switch role priority 10 peer-keepalive destination 172.30.0.32 source 172.30.0.31 delay restore 90 peer-gateway delay restore interface-vlan 30 ip arp synchronize interface Vlan1 no ip redirects no ipv6 redirects interface Vlan100 description ** Anycast Gateway For Public ** no shutdown mtu 9216 vrf member CUST1 ip address 60.25.124.1/23 fabric forwarding mode anycast-gateway interface Vlan444 description ** Underlay Backup over vPC Peer-Link ** no shutdown ip address 192.168.1.1/30 ip ospf authentication-key 3 fa3ab8e90610229c ip ospf network point-to-point ip router ospf UNDERLAY-NET area 0.0.0.0 ip pim sparse-mode interface Vlan555 description ** L3VNI-For-IRB ** no shutdown mtu 9216 vrf member CUST1 ip forward interface port-channel111 description ** Link to enc-k001-1-a ** switchport mode trunk switchport trunk allowed vlan 64-68,70,100 mtu 9216 speed 10000 vpc 111 interface port-channel112 description ** Link to enc-k001-1-b ** switchport mode trunk switchport trunk allowed vlan 64-68,70,100 mtu 9216 speed 10000 vpc 112 interface port-channel121 description ** Link to enc-k001-2-a ** switchport mode trunk switchport trunk allowed vlan 64-68,70,100 mtu 9216 speed 10000 vpc 121 interface port-channel122 description ** Link to enc-k001-2-b ** switchport mode trunk switchport trunk allowed vlan 64-68,70,100 mtu 9216 speed 10000 vpc 122 interface port-channel211 description ** Link to enc-k002-1-a ** switchport mode trunk switchport trunk allowed vlan 64-68,70,100 mtu 9216 speed 10000 vpc 211 interface port-channel212 description ** Link to enc-k002-1-b ** switchport mode trunk switchport trunk allowed vlan 64-68,70,100 mtu 9216 speed 10000 vpc 212 interface port-channel221 description ** Link to enc-k002-2-a ** switchport mode trunk switchport trunk allowed vlan 64-68,70,100 mtu 9216 speed 10000 vpc 221 interface port-channel222 description ** Link to enc-k002-2-b ** switchport mode trunk switchport trunk allowed vlan 64-68,70,100 mtu 9216 speed 10000 vpc 222 interface port-channel311 description ** Link to enc-k003-1-a ** switchport mode trunk switchport trunk allowed vlan 64-68,70,100 mtu 9216 speed 10000 vpc 311 interface port-channel312 description ** Link to enc-k003-1-b ** switchport mode trunk switchport trunk allowed vlan 64-68,70,100 mtu 9216 speed 10000 vpc 312 interface port-channel321 description ** Link to enc-k003-2-a ** switchport mode trunk switchport trunk allowed vlan 64-68,70,100 mtu 9216 speed 10000 vpc 321 interface port-channel322 description ** Link to enc-k003-2-b ** switchport mode trunk switchport trunk allowed vlan 64-68,70,100 mtu 9216 speed 10000 vpc 322 interface port-channel999 description ** vPC Peer-Link ** switchport mode trunk switchport trunk allowed vlan 64-68,70,100,444,555 spanning-tree port type network speed 40000 no negotiate auto vpc peer-link interface nve1 no shutdown description ** VTEP/NVE Interface ** host-reachability protocol bgp source-interface loopback1 member vni 10064 suppress-arp mcast-group 239.1.1.1 member vni 10065 suppress-arp mcast-group 239.1.1.1 member vni 10066 suppress-arp mcast-group 239.1.1.1 member vni 10067 suppress-arp mcast-group 239.1.1.1 member vni 10068 suppress-arp mcast-group 239.1.1.1 member vni 10070 mcast-group 239.1.1.1 member vni 10100 suppress-arp mcast-group 239.1.1.1 member vni 10555 associate-vrf interface Ethernet1/1 description ** Link to swt-enc-k001-1-a Port E18 ** no cdp enable switchport mode trunk switchport trunk allowed vlan 64-68,70,100 mtu 9216 speed 10000 channel-group 111 mode active interface Ethernet1/2 description ** Link to swt-enc-k001-1-a Port E19 ** no cdp enable switchport mode trunk switchport trunk allowed vlan 64-68,70,100 mtu 9216 speed 10000 channel-group 111 mode active interface Ethernet1/3 description ** Link to swt-enc-k001-1-b Port E18 ** no cdp enable switchport mode trunk switchport trunk allowed vlan 64-68,70,100 mtu 9216 speed 10000 channel-group 112 mode active interface Ethernet1/4 description ** Link to swt-enc-k001-1-b Port E19 ** no cdp enable switchport mode trunk switchport trunk allowed vlan 64-68,70,100 mtu 9216 speed 10000 channel-group 112 mode active interface Ethernet1/5 description ** Link to swt-enc-k001-2-a Port E18 ** no cdp enable switchport mode trunk switchport trunk allowed vlan 64-68,70,100 mtu 9216 speed 10000 channel-group 121 mode active interface Ethernet1/6 description ** Link to swt-enc-k001-2-a Port E19 ** no cdp enable switchport mode trunk switchport trunk allowed vlan 64-68,70,100 mtu 9216 speed 10000 channel-group 121 mode active interface Ethernet1/7 description ** Link to swt-enc-k001-2-b Port E18 ** no cdp enable switchport mode trunk switchport trunk allowed vlan 64-68,70,100 mtu 9216 speed 10000 channel-group 122 mode active interface Ethernet1/8 description ** Link to swt-enc-k001-2-b Port E19 ** no cdp enable switchport mode trunk switchport trunk allowed vlan 64-68,70,100 mtu 9216 speed 10000 channel-group 122 mode active interface Ethernet1/9 shutdown mtu 9216 interface Ethernet1/10 description ** Link to VMware Host-1 ** switchport mode trunk switchport trunk allowed vlan 64-65,70,100 spanning-tree port type edge trunk mtu 9216 speed 10000 interface Ethernet1/17 description ** Link to swt-enc-k002-1-a Port E18 ** no cdp enable switchport mode trunk switchport trunk allowed vlan 64-68,70,100 mtu 9216 speed 10000 channel-group 211 mode active interface Ethernet1/18 description ** Link to swt-enc-k002-1-a Port E19 ** no cdp enable switchport mode trunk switchport trunk allowed vlan 64-68,70,100 mtu 9216 speed 10000 channel-group 211 mode active interface Ethernet1/19 description ** Link to swt-enc-k002-1-b Port E18 ** no cdp enable switchport mode trunk switchport trunk allowed vlan 64-68,70,100 mtu 9216 speed 10000 channel-group 212 mode active interface Ethernet1/20 description ** Link to swt-enc-k002-1-b Port E19 ** no cdp enable switchport mode trunk switchport trunk allowed vlan 64-68,70,100 mtu 9216 speed 10000 channel-group 212 mode active interface Ethernet1/21 description ** Link to swt-enc-k002-2-a Port E18 ** no cdp enable switchport mode trunk switchport trunk allowed vlan 64-68,70,100 mtu 9216 speed 10000 channel-group 221 mode active interface Ethernet1/22 description ** Link to swt-enc-k002-2-a Port E19 ** no cdp enable switchport mode trunk switchport trunk allowed vlan 64-68,70,100 mtu 9216 speed 10000 channel-group 221 mode active interface Ethernet1/23 description ** Link to swt-enc-k002-2-b Port E18 ** no cdp enable switchport mode trunk switchport trunk allowed vlan 64-68,70,100 mtu 9216 speed 10000 channel-group 222 mode active interface Ethernet1/24 description ** Link to swt-enc-k002-2-b Port E19 ** no cdp enable switchport mode trunk switchport trunk allowed vlan 64-68,70,100 mtu 9216 speed 10000 channel-group 222 mode active interface Ethernet1/33 description ** Link to swt-enc-1-a Port E18 **k003 no cdp enable switchport mode trunk switchport trunk allowed vlan 64-68,70,100 mtu 9216 speed 10000 channel-group 311 mode active interface Ethernet1/34 description ** Link to swt-enc-k003-1-a Port E19 ** no cdp enable switchport mode trunk switchport trunk allowed vlan 64-68,70,100 mtu 9216 speed 10000 channel-group 311 mode active interface Ethernet1/35 description ** Link to swt-enc-k003-1-b Port E18 ** no cdp enable switchport mode trunk switchport trunk allowed vlan 64-68,70,100 mtu 9216 speed 10000 channel-group 312 mode active interface Ethernet1/36 description ** Link to swt-enc-k003-1-b Port E19 ** no cdp enable switchport mode trunk switchport trunk allowed vlan 64-68,70,100 mtu 9216 speed 10000 channel-group 312 mode active interface Ethernet1/37 description ** Link to swt-enc-2-a Port E18 **k003 no cdp enable switchport mode trunk switchport trunk allowed vlan 64-68,70,100 mtu 9216 speed 10000 channel-group 321 mode active interface Ethernet1/38 description ** Link to swt-enc-k003-2-a Port E19 ** no cdp enable switchport mode trunk switchport trunk allowed vlan 64-68,70,100 mtu 9216 speed 10000 channel-group 321 mode active interface Ethernet1/39 description ** Link to swt-enc-k003-2-b Port E18 ** no cdp enable switchport mode trunk switchport trunk allowed vlan 64-68,70,100 mtu 9216 speed 10000 channel-group 322 mode active interface Ethernet1/40 description ** Link to swt-enc-k003-2-b Port E19 ** no cdp enable switchport mode trunk switchport trunk allowed vlan 64-68,70,100 mtu 9216 speed 10000 channel-group 322 mode active interface Ethernet2/1 description ** Spine-1 ** no switchport mtu 9216 medium p2p ip address 10.1.11.1/31 ip ospf authentication-key 3 XXXXXXX ip ospf network point-to-point ip router ospf UNDERLAY-NET area 0.0.0.0 ip pim sparse-mode no shutdown interface Ethernet2/2 description ** Spine-2 ** no switchport mtu 9216 medium p2p ip address 10.2.11.1/31 ip ospf authentication-key 3 XXXXXXX ip ospf network point-to-point ip router ospf UNDERLAY-NET area 0.0.0.0 ip pim sparse-mode no shutdown interface Ethernet2/11 description ** vPC Peer-Link ** switchport mode trunk switchport trunk allowed vlan 64-68,70,100,444,555 speed 40000 no negotiate auto channel-group 999 mode active interface Ethernet2/12 description ** vPC Peer-Link ** switchport mode trunk switchport trunk allowed vlan 64-68,70,100,444,555 speed 40000 no negotiate auto channel-group 999 mode active interface mgmt0 vrf member management no ip redirects ip address 172.30.0.31/23 interface loopback0 description ** RID/BGP Overlay ** ip address 10.255.1.11/32 ip router ospf UNDERLAY-NET area 0.0.0.0 ip pim sparse-mode interface loopback1 description ** VTEP/Overlay ** ip address 10.255.255.11/32 ip address 10.255.255.10/32 secondary ip ospf authentication-key 3 fa3ab8e90610229c ip router ospf UNDERLAY-NET area 0.0.0.0 ip pim sparse-mode cli alias name wr copy running-config startup-config line console line vty boot nxos bootflash:/nxos.9.3.4.bin router ospf UNDERLAY-NET router-id 10.255.1.11 log-adjacency-changes area 0.0.0.0 authentication router bgp 65001 router-id 10.255.1.11 log-neighbor-changes template peer VXLAN_SPINE remote-as 65001 update-source loopback0 address-family ipv4 unicast address-family l2vpn evpn send-community send-community extended neighbor 10.255.0.1 inherit peer VXLAN_SPINE description ** iBGP Peer to Spine-1 ** neighbor 10.255.0.2 inherit peer VXLAN_SPINE description ** iBGP Peer to Spine-2 ** vrf CUST1 log-neighbor-changes address-family ipv4 unicast redistribute direct route-map DIRECT-PERMIT-ALL evpn vni 10064 l2 rd auto route-target import auto route-target export auto vni 10065 l2 rd auto route-target import auto route-target export auto vni 10066 l2 rd auto route-target import auto route-target export auto vni 10067 l2 rd auto route-target import auto route-target export auto vni 10068 l2 rd auto route-target import auto route-target export auto vni 10070 l2 rd auto route-target import auto route-target export auto vni 10100 l2 rd auto route-target import auto route-target export auto
