03-16-2020 05:53 AM
Anyone ever get Macsec towards Azure up and running? We have a IOS-XE-switch, and followed the configuration guide for Macsec with PSK here: https://www.cisco.com/c/en/us/td/docs/iosxr/ncs5500/security/62x/b-system-security-cg-ncs5500-62x/b-system-security-cg-ncs5500-62x_chapter_0101.html#concept_gjz_ysl_vcb
The second we enable "macsec network-link" toward azure, the line-protocol goes down, and show mka summary says the link is in Init-mode. Nothing happens after that, and can see no packets from the other end with debugs. Problem is Microsoft Azure-guys have had a look, and everything looks good on their end. Ideas?
Solved! Go to Solution.
02-22-2021 09:22 AM
Azure uses Juniper box - had to enable sci on Juniper
Cause:
In this situation, the 'include-sci' is 'yes' by default on the Cisco switch, while it is optional for Juniper.
Solution:
Add 'include-sci' on the Juniper Router MACSEC configuration as follows:
#set security macsec connectivity-association connectivity-association-name include-sci
03-19-2020 07:55 AM
I'm a bit of a novice at cloud connectivity but who/how are you getting connectivity into Azure? Are you peering with them directly or via. some third party like Megaport?
Jason.
03-19-2020 10:30 AM
Microsoft offers a direct connection called Expressroute Direct, and on that type of connection you can get macsec. Just not quite sure how to troubleshoot this when i dont have control of the other end. Cant see anything in the logs relating to wrong PSK or anything like that, what else can i do on my end to troubleshoot?
03-19-2020 05:35 PM
So with this you get a direct circuit to Azure like they physically give you a cable/handoff? So it's L1 all the way to their service?
03-19-2020 11:17 PM
Yup
04-05-2020 10:22 PM
Hey,
Did anyone find any resolution with this?
04-05-2020 10:44 PM
Not yet, still an ongoing case with ms-support. They seem to have found some issues on their end, but were not rocking macsec yet :( Ill update as soon as we get a cause.
04-06-2020 12:00 AM
04-07-2020 02:37 AM
So this is a WAN Macsec implementation then? Is that supported in MS with the 802.1Q header in the clear, or have i misunderstood your setup?
02-02-2021 12:42 AM
Hello. I'm interested to have a status on this topic. Is it finally working?
02-02-2021 12:46 AM
No, we have the session up, but not actually forwarding traffic. This is just a weird issue, but hopefully we are having a maintenance window this week, will update at that point.
02-22-2021 09:22 AM
Cause:
Solution:
02-22-2021 11:08 PM
Thanks for your suggestion, have fired it off to Microsoft now, and we will try in the next maintenance window (has taken forever this
07-19-2021 03:18 AM
Hi @trondaker. I was wondering if this was resolved for you. Were the Microsoft guys able to configure this and did it solve your problem?
07-19-2021 05:44 AM
Hi @leon.teheux - yea, MS engineering enabled SCI on their end and everything worked as expected. Cisco confirmed that they do not have an option to disable on their end.
