faiulare Nexus 7k
Javier Acuña
Hello to all colleagues in the cisco community, today I request help during the following scenario:
1) I have two data centers connected by OTV under Nexus 7k IOS platform (n7000-s1-dk9.6.2.22). Under four devices.
2) I have extended vlans between the two datacenters.
3) A reboot of one of the devices in Data center A is executed, specifically device B (secondary) when entering the network, this device connected to the vdc domain without any problem and joined the network, but one of the SVI ( vlan ) has problems with the arp table, (it is observed that it learns the mac add on Nexus A but when trying an ICMP communication towards the Nexus 5k downstream connection the communication is not satisfactory, it should be noted that the mac add is learned on both devices, but can not communicate how this is possible?
Have any of you had a problem similar to the one mentioned?
Is there any way to run some solution for this configuration.
The Vlan mentions the following Flags status: * - Adjacencies learned in FHRP router not active
10.xx.xx.xx 00:00:23 xxxx.xxxx.xxx Vlan1xxx *
below I share the communication diagram.
0 Replies 0
