Feature Parity of QinQ between NXOS and ACI
svenus
Customer is on ACI and is after to refresh with simpler deployment with EVPN-VXLAN on standalone NXOS. They provided just this output on ACI. Is there any other stuff to check what exactly I need to match on NXOS?
It seems that the existing environment has two ports in the same EPG:
1 with double tagged.
1 with single dot1q tag.
And the bridge domain allows them to talk to each other.
It looks like NXOS only transport QinQ, but not able to strip off the outer VLAN when double tagged frames coming ingress?
Thoughts?
AshSe
Hello @svenus
You need to gather more details from the ACI configuration to accurately replicate the behavior in NX-OS.
Hope This Helps!!!
AshSe
Community Etiquette:
  1. Insert photos/images inline - don't attach.
  1. Always mark helpful and correct answers, it helps others find what they need.
  1. For a prompt reply, kindly tag @name. An email will be automatically sent to the member.
Thanks.
I logged a TAC case the other day and got a reference configuration.  I'll leave the reference in case someone need it in the future:  SR 698929000 Configuration Assistance - Match up existing ACI QinQ configuration and migrate to NXOS
