Help required for Datacenter planning and implementation - Single Legged Architecture
ashwin_kuhikar
Hi Team,
I have few queries regarding the planning phase for migration of 5 application/servers from XYZ datacenter to new datacenter which is presented in the diagram. The diagram provided contain the devices which will be used in the DC. We have 3 firewalls, one external/internet firewall (on right side), 2nd VPN gateway (on right above internet firewall) for establishing VPN connectivity to offshore team and 3rd internal firewall (on left).
MPLS connectivity:
We have a MPLS connection on ISR MPLS router which will connect the XYZ DC to my new DC.
Internet connectivity:
We have 200 Mbps link for internet and VPN connectivity for my new DC.
Nexus is the core device which will be used as a gate way to connect all servers.
Queries:
1. What will be my configuration on nexus for servers, should it be vrf or vlan?
2. what protocol do i use to route my traffic to XYZ DC ? should it be dynamic or static routing?
3. Need help in VPN and internet connectivity .
Ashwin
balaji.bandi
This is trusted servers, Then VLAN good enough to start with.
If you do not have dynamic routing place, you can start with Static routing
explain more ? for these servers to reach via internet ?
BB
Need VPN for offshore connectivity from the Datacenter. This VPN will be established via the same internet link. The another use of internet would be to provide internet connectivity to servers.
Also can i have a VM in LAN segment where i can have internet connectivity and LAN connectivity on the same device ?
As per security concerns and best practice, do no mix Internet and LAN in same VM, (it is possible) but not recommended in the security context.
BB
