08-06-2020 04:27 PM - edited 08-06-2020 05:04 PM
Dear all,
I would just like to configure 1Gbps Output Shaping on Neuxs93180-YC-FX.
Before I have confirmed the QoS Traffic Shaping on Neuxs9372TX-E like the following configuration however
if I configures on Nexus93180YC-FX it shows the following output. I would like to find out any reason not to configure it.
NXOS: version 9.3(1)
Nexus93180YC-FX(config)# policy-map type queuing SHAPE Nexus93180YC-FX(config-pmap-que)# class type queuing c-out-q1 Nexus93180YC-FX(config-pmap-c-que)# bandwidth remaining percent 0 Nexus93180YC-FX(config-pmap-c-que)# class type queuing c-out-q2 Nexus93180YC-FX(config-pmap-c-que)# bandwidth remaining percent 0 Nexus93180YC-FX(config-pmap-c-que)# class type queuing c-out-q3 Nexus93180YC-FX(config-pmap-c-que)# bandwidth remaining percent 0 Nexus93180YC-FX(config-pmap-c-que)# class type queuing c-out-q-default Nexus93180YC-FX(config-pmap-c-que)# bandwidth remaining percent 100 Nexus93180YC-FX(config-pmap-c-que)# shape min 0 gbps max 1 gbps Nexus93180YC-FX(config-pmap-c-que)# Nexus93180YC-FX(config-pmap-c-que)# interface Ethernet1/50 -policy type queuing output SHAPE Nexus93180YC-FX(config-if)# service-policy type queuing output SHAPE Unable to perform the action due to incompatibility: Module 1 returned status "The template types for system and interface level policies do not match. Please reconfigure"
The following is CCO manual however I can not find this out.
[Cisco Nexus 9000 Series NX-OS Quality of Service Configuration Guide, Release 9.3(x)]
https://www.cisco.com/c/en/us/td/docs/switches/datacenter/nexus9000/sw/93x/qos/configuration/guide/b-cisco-nexus-9000-nx-os-quality-of-service-configuration-guide-93x/b-cisco-nexus-9000-nx-os-quality-of-service-configuration-guide-93x_chapter_01000.h...
Best Regards,
Masanobu Hiyoshi
08-06-2020 11:54 PM
Hi @mhiyoshi
You should verify what network-qos is configured on your system:
N9K# show policy-map system type network-qos Type network-qos policy-maps ============================ policy-map type network-qos default-8q-nq-policy (....)
if is the "default-8q-nq-policy" template, then you might want to change it to "default-nq-policy"
Command to verify available default network-qos policy maps:
N9K# show policy-map type network-qos
To change the systm network-qos template:
N9K(config)# system qos N9K(config-sys-qos)# service-policy type network-qos default-nq-policy N9K(config-sys-qos)# show policy-map system type network-qos Type network-qos policy-maps ============================ policy-map type network-qos default-nq-policy class type network-qos c-nq3 match qos-group 3 mtu 1500 class type network-qos c-nq2 match qos-group 2 mtu 1500 class type network-qos c-nq1 match qos-group 1 mtu 1500 class type network-qos c-nq-default match qos-group 0 mtu 1500
Let us know what is the result.
Stay safe,
Sergiu
08-07-2020 12:46 AM
Hi msdaniluk,
Thank you for your reply! Based on your sample configuration, I have verified with the following, is it possible to configure on interface level output Shaping?
Nexus93180YC-FX(config)# system qos Nexus93180YC-FX(config-sys-qos)# service-policy type network-qos de default-8q-nq-policy default-nq-policy Nexus93180YC-FX(config-sys-qos)# service-policy type network-qos default-nq-policy Nexus93180YC-FX(config-sys-qos)# exit Nexus93180YC-FX(config)# Nexus93180YC-FX(config)# policy-map type network-qos SHAPE Nexus93180YC-FX(config-pmap-nqos)# class type network-qos ? c-8q-nq-default Default class on qos-group 0 c-8q-nq1 Default class on qos-group 1 c-8q-nq2 Default class on qos-group 2 c-8q-nq3 Default class on qos-group 3 c-8q-nq4 Default class on qos-group 4 c-8q-nq5 Default class on qos-group 5 c-8q-nq6 Default class on qos-group 6 c-8q-nq7 Default class on qos-group 7 c-nq-default Default class on qos-group 0 c-nq1 Default class on qos-group 1 c-nq2 Default class on qos-group 2 c-nq3 Default class on qos-group 3 class-default (no abbrev) System default class matching otherwise not classified cos values Nexus93180YC-FX(config-pmap-nqos)# class type network-qos c-nq-default Nexus93180YC-FX(config-pmap-nqos-c)# ? congestion-control Congestion Control Protocol dpp Dynamic Packet Prioritization mtu MTU for the CoS no Negate a command or set its defaults pause PAUSE charecteristics (CBFC) show Show running system information end Go to exec mode exit Exit from command interpreter pop Pop mode from stack or restore from name push Push current mode to stack or save it under name where Shows the cli context you are in
Best Regards,
Masanobu Hiyoshi
08-07-2020 03:32 AM - edited 08-07-2020 03:39 AM
Hello!
The default system-wide queueing policy on the Nexus 93180YC-FX is an eight-queue policy. The queuing policy you are attempting to apply to interfaces only has four queues configured. As a result, the device throws an error message, because theoretically, you could classify traffic into a queue that is not configured for any QoS actions (shaping, policing, marking, etc.) on the interface where your policy is applied.
To fix this, we have one of two options:
If you only need four queues, the simplest solution is the second one, which involves applying the following configuration:
N9K# configure terminal
Enter configuration commands, one per line. End with CNTL/Z.
N9K(config-sys-qos)# service-policy type queuing output default-out-policy
N9K(config-sys-qos)# end
N9K#
To be clear, the default-out-policy should already exist on the device. There is no need to create this policy-map on the device.
After this configuration is applied, you should be able to apply your queuing policy-map to the interface successfully.
I hope this helps!
-Christopher
08-07-2020 03:55 AM
Ok, so I see you've changed the network-qos policy (great explanation covered by @Christopher Hart why you need to do that).
Now all it's left to do is retry the interface service-policy configuration.
Stay safe,
Sergiu
08-07-2020 04:28 AM - edited 08-07-2020 04:29 AM
Hi Christopher, msdaniluk,
Thank you for your advice, it was too much HTH!! (Hope This Helps)
So promptly I have configured the following but it seems not to be configurable under the default-out-policy...
(is that right? if there is other option I appreciate..)
Nexus93180YC-FX(config)# system qos Nexus93180YC-FX(config-sys-qos)# service-policy type queuing output default-out-policy Nexus93180YC-FX(config-sys-qos)# policy-map type queuing default-out-policy Cannot modify system defined queuing policy-maps
Finally I have configured the following it seems configurable for 1Gbps Traffic Shaping output direction on interface level.
Nexus93180YC-FX(config)# policy-map type queuing SHAPE Nexus93180YC-FX(config-pmap-que)# class type queuing c-out-q1 Nexus93180YC-FX(config-pmap-c-que)# bandwidth remaining percent 0 Nexus93180YC-FX(config-pmap-c-que)# class type queuing c-out-q2 Nexus93180YC-FX(config-pmap-c-que)# bandwidth remaining percent 0 Nexus93180YC-FX(config-pmap-c-que)# class type queuing c-out-q3 Nexus93180YC-FX(config-pmap-c-que)# bandwidth remaining percent 0 Nexus93180YC-FX(config-pmap-c-que)# class type queuing c-out-q-default Nexus93180YC-FX(config-pmap-c-que)# bandwidth remaining percent 100 Nexus93180YC-FX(config-pmap-c-que)# shape min 0 gbps max 1 gbps Nexus93180YC-FX(config-pmap-c-que)# Nexus93180YC-FX(config-pmap-c-que)# system qos Nexus93180YC-FX(config-sys-qos)# service-policy type queuing output SHAPE Nexus93180YC-FX(config-sys-qos)# int e1/50 Nexus93180YC-FX(config-if)# service-policy type queuing output SHAPE Nexus93180YC-FX(config-if)# end
I think the verification in my opinion I can expect what to do.
Nexus93180YC-FX# sh policy-map interface ethernet 1/50 output Global statistics status : enabled Ethernet1/50 Service-policy (queuing) output: SHAPE SNMP Policy Index: 301993525 Class-map (queuing): c-out-q-default (match-any) bandwidth remaining percent 100 shape min 0 gbps max 1 gbps queue dropped pkts : 0 queue depth in bytes : 0 Class-map (queuing): c-out-q1 (match-any) bandwidth remaining percent 0 queue dropped pkts : 0 queue depth in bytes : 0 Class-map (queuing): c-out-q2 (match-any) bandwidth remaining percent 0 queue dropped pkts : 0 queue depth in bytes : 0 Class-map (queuing): c-out-q3 (match-any) bandwidth remaining percent 0 queue dropped pkts : 0 queue depth in bytes : 0
Best Regards,
Masanobu Hiyoshi
08-07-2020 04:38 AM
Hello!
According to the provided session logs and your verification show command, it looks like your shaping policy on Ethernet1/50 was successfully applied after we changed the default output queuing policy to a four-queue model - I am glad to see this!
I can confirm that it is expected behavior for the Nexus to return an error message when running the policy-map type queuing default-out-policy command. This command implies you want to re-configure this policy-map, which is not allowed as it is a default policy-map (meaning, it comes pre-configured on the system and cannot be changed.)
If you wanted to define your own system-wide output queuing policy, you would need to do the following:
@Sergiu.Daniluk - Thank you for the kudos! As a side note, I believe we needed to change both the system-wide network-qos policy and the system-wide default output queuing policy to a four-queue model (although I've not explicitly tested this - it may work with an eight-queue model defined in a network-qos policy, but a four-queue model in the default output queuing policy.)
Thank you!
-Christopher
08-07-2020 04:42 AM
Hi Christopher,
Thank you very much, Yes 1 & 2 you mentioned are very important now I can memorize them
Best Regards,
Masanobu Hiyoshi
08-07-2020 05:38 AM
You are correct. Configuration is allowed with only queuing policy changed to 4q and leaving network-qos in 8q model. Just tested in lab and works. On the other hand, the ingress will continue to use 8 queues, I am just thinking if and how this will affect traffic matching Q4-Q7.
08-17-2020 11:53 PM - edited 08-18-2020 12:41 AM
Hi thank you for your support and this is one tips.
According to the CCO manual below, I think it seems the default system qos queuing template is 4q however,
the real device is booting up as 8q on the device and NX-OS below however I can not understand the reason
and I have not find out any evidence...
Can you think there is any related information such as release note etc?
https://www.cisco.com/c/en/us/td/docs/switches/datacenter/nexus9000/sw/93x/qos/configuration/guide/b-cisco-nexus-9000-nx-os-quality-of-service-configuration-guide-93x/b-cisco-nexus-9000-nx-os-quality-of-service-configuration-guide-93x_chapter_011.htm...
Changing to 8q Mode
The Cisco Nexus 9000 series NX-OS system operates in 4q mode by default.
NXOS: version 9.3(1) N9K-C93180YC-FX Nexus9K# sh running-config all | be "system qos" system qos service-policy type network-qos default-8q-nq-policy service-policy type queuing output default-8q-out-policy
Best Regards,
Masanobu Hiyoshi
10-08-2020 01:57 PM
I am having similar issue and unable to fix it, can you help ?
N9K-C93180YC-FX(config-if)# int eth1/35
N9K-C93180YC-FX(config-if)# service-policy type queuing output Output-QoS-1Gbps
Unable to perform the action due to incompatibility: Module 1 returned status "The template types for system and interface level policies do not match. Please reconfigure" >>>>>>>>>>>>> ERROR
N9K-C93180YC-FX(config-if)# show policy-map system type network-qos
class type network-qos c-8q-nq7
match qos-group 7
mtu 1500
class type network-qos c-8q-nq6
match qos-group 6
mtu 1500
class type network-qos c-8q-nq5
match qos-group 5
mtu 1500
class type network-qos c-8q-nq4
match qos-group 4
mtu 1500
class type network-qos c-8q-nq3
match qos-group 3
mtu 1500
class type network-qos c-8q-nq2
match qos-group 2
mtu 1500
class type network-qos c-8q-nq1
match qos-group 1
mtu 1500
class type network-qos c-8q-nq-default
match qos-group 0
mtu 1500
N9K-C93180YC-FX(config)# system qos
N9K-C93180YC-FX(config-sys-qos)# service-policy type network-qos default-nq-policy <<<<<<< CHANGED to default-nq-policy
N9K-C93180YC-FX(config-sys-qos)# show policy-map system type network-qos
match qos-group 3
mtu 1500
match qos-group 2
mtu 1500
match qos-group 1
mtu 1500
match qos-group 0
mtu 1500
N9K-C93180YC-FX(config-sys-qos)# exit
N9K-C93180YC-FX(config)# int eth1/35
N9K-C93180YC-FX(config-if)# service-policy type qos input Input-QoS no-stats
Unable to perform the action due to incompatibility: Module 1 returned status "The template types for system and interface level policies do not match. Please reconfigure" <<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<< STILL DOESN'T WORK
N9K-C93180YC-FX(config-if)# exit
N9K-C93180YC-FX(config-sys-qos)# policy-map type network-qos default-8q-nq-policy
Cannot modify system defined network-qos policy-maps <<<<<<<<<<<<<<<<<<<<<<<<<<<<<< NOW CAN'T EVEN CHANGE BACK TO default-8q-nq-policy
N9K-C93180YC-FX(config)# sh policy-map int eth1/35 output
Ethernet1/35
Service-policy (queuing) output: default-8q-out-policy >>>>>>> BUT here it still shows 8Q-OUT-policy, WHY ????
SNMP Policy Index: 301990364
Class-map (queuing): c-out-8q-q7 (match-any)
priority level 1
Class-map (queuing): c-out-8q-q6 (match-any)
Class-map (queuing): c-out-8q-q5 (match-any)
Class-map (queuing): c-out-8q-q4 (match-any)
10-08-2020 02:01 PM
N9K-C93180YC-FX# show module
Mod Ports Module-Type Model Status
1 54 48x10/25G + 6x40/100G Ethernet Module N9K-C93180YC-FX active *
Mod Sw Hw Slot
1 7.0(3)I7(1) 2.2 NA
