06-15-2019 12:47 PM
How to connect modem to Nexus 3048? should I use the RS-232 Serial console port
Solved! Go to Solution.
06-15-2019 09:34 PM
06-15-2019 04:36 PM
06-15-2019 08:14 PM
Thank you so much, Francesco.
I mean if I should use RS232 serial port to connect to a modem? I need to use a phone number to dail in as the out-of-band access to the switch.
Best Regards,
Vinson
06-15-2019 09:34 PM
