How to verify SVI (Routed) ACL per-entry counter and Physical interface on Nexus9K?
mhiyoshi
Level 3
Level 3
Dear all,
When it configures like the following, it can verify without statistics per-entry however I can not check the relationship between
the configured ACL and Physical interface, if the show hardware access-list vlan [vlan-id] input statistics, it shows INSTANCE value like 0x0 and 0x1.
Is it possible to check the relationship between SVI RACL per-entry counters and physical interface?
here is the verification output:
INSTANCE 0x0 ===== E1/30(ACL conifgured)
       Policies: RACL(TEST)  [Merged]
       Entries:
         [Index] Entry [Stats]
  [0x0000:0x0002:0x0002] permit ip 1.1.1.1/32 5.5.5.5/32  routeable 0x1  [9]
  [0x0001:0x0003:0x0003] deny ip 0.0.0.0/0 0.0.0.0/0  routeable 0x1  [28]
INSTANCE 0x1 ===== E1/1(ACL additionally configured)
       Entries:
  [0x0000:0x0002:0x0002] permit ip 1.1.1.1/32 5.5.5.5/32  routeable 0x1  [0]
  [0x0001:0x0003:0x0003] deny ip 0.0.0.0/0 0.0.0.0/0  routeable 0x1  [0]
[ACL-config]
interface Vlan10
  ip access-group TEST in
interface Ethernet1/30
  switchport
  switchport access vlan 10
Nexus9K# sh hardware access-list vlan 10 input statistics
slot  1
INSTANCE 0x0
  Tcam 1 resource usage:
  LBL B = 0x1
   Bank 1
     IPv4 Class
       Netflow profile: 0
       Netflow deny profile: 0
       Entries:
  [0x0000:0x0002:0x0002] permit ip 1.1.1.1/32 5.5.5.5/32  routeable 0x1  [3]
  [0x0001:0x0003:0x0003] deny ip 0.0.0.0/0 0.0.0.0/0  routeable 0x1  [15]
==> additional interface
Nexus9K(config)# int E1/1
Nexus9K(config-if)# switchport
Nexus9K(config-if)# switchport access vlan 10
slot  1
INSTANCE 0x0
  LBL B = 0x1
   Bank 1
     IPv4 Class
       Netflow profile: 0
       Entries:
INSTANCE 0x1
  LBL B = 0x1
   Bank 1
     IPv4 Class
       Netflow profile: 0
       Entries:
Sergiu.Daniluk
Hi @mhiyoshi
Just to understand, you want to see the match counters per interface of an ACL applies on a SVI? That is not possible.
In the command you just used you see the counters per ASIC TCAM Instance.
You can try to use Port ACL with statistics per-entry enabled and apply the ACLs on the desired interfaces.
Stay safe,
Sergiu
Hi, thank you very much!
Yes, if ACL with statistics per-entry then it shows ACL counter like [XXX], however in case of interface vlan (SVI) with ACL,
If I configure with switchport access vlan [vlan-id] on several physical interface, it creates INSTANCE value like 0x0, 0x1 etc.
So it can be helpful if I can check which physical interface is related to the created INSTANCE value.
Best Regards,
Masanobu Hiyoshi
Sergiu.Daniluk
HI @mhiyoshi
Again, instance is just the TCAM (ASIC) instance. Is not the interface.
You only see the Instance the interface belong to.
Stay safe,
Sergiu
mhiyoshi
Level 3
Level 3
Hi msdaniluk,
Thank you very much.
