Dear all,
When it configures like the following, it can verify without statistics per-entry however I can not check the relationship between
the configured ACL and Physical interface, if the show hardware access-list vlan [vlan-id] input statistics, it shows INSTANCE value like 0x0 and 0x1.
Is it possible to check the relationship between SVI RACL per-entry counters and physical interface?
here is the verification output:
########################################################################################## INSTANCE 0x0 ===== E1/30(ACL conifgured) Policies: RACL(TEST) [Merged] Entries: [Index] Entry [Stats] --------------------- [0x0000:0x0002:0x0002] permit ip 1.1.1.1/32 5.5.5.5/32 routeable 0x1 [9] [0x0001:0x0003:0x0003] deny ip 0.0.0.0/0 0.0.0.0/0 routeable 0x1 [28] INSTANCE 0x1 ===== E1/1(ACL additionally configured) Policies: RACL(TEST) [Merged] Entries: [Index] Entry [Stats] --------------------- [0x0000:0x0002:0x0002] permit ip 1.1.1.1/32 5.5.5.5/32 routeable 0x1 [0] [0x0001:0x0003:0x0003] deny ip 0.0.0.0/0 0.0.0.0/0 routeable 0x1 [0] ########################################################################################## [ACL-config] interface Vlan10 ip access-group TEST in interface Ethernet1/30 switchport switchport access vlan 10 Nexus9K# sh hardware access-list vlan 10 input statistics slot 1 ======= INSTANCE 0x0 --------------- Tcam 1 resource usage: ---------------------- LBL B = 0x1 Bank 1 ------ IPv4 Class Policies: RACL(TEST) [Merged] Netflow profile: 0 Netflow deny profile: 0 Entries: [Index] Entry [Stats] --------------------- [0x0000:0x0002:0x0002] permit ip 1.1.1.1/32 5.5.5.5/32 routeable 0x1 [3] [0x0001:0x0003:0x0003] deny ip 0.0.0.0/0 0.0.0.0/0 routeable 0x1 [15] ########################################################################################## ==> additional interface Nexus9K(config)# int E1/1 Nexus9K(config-if)# switchport Nexus9K(config-if)# switchport access vlan 10 Nexus9K# sh hardware access-list vlan 10 input statistics slot 1 ======= INSTANCE 0x0 --------------- Tcam 1 resource usage: ---------------------- LBL B = 0x1 Bank 1 ------ IPv4 Class Policies: RACL(TEST) [Merged] Netflow profile: 0 Netflow deny profile: 0 Entries: [Index] Entry [Stats] --------------------- [0x0000:0x0002:0x0002] permit ip 1.1.1.1/32 5.5.5.5/32 routeable 0x1 [9] [0x0001:0x0003:0x0003] deny ip 0.0.0.0/0 0.0.0.0/0 routeable 0x1 [28] INSTANCE 0x1 --------------- Tcam 1 resource usage: ---------------------- LBL B = 0x1 Bank 1 ------ IPv4 Class Policies: RACL(TEST) [Merged] Netflow profile: 0 Netflow deny profile: 0 Entries: [Index] Entry [Stats] --------------------- [0x0000:0x0002:0x0002] permit ip 1.1.1.1/32 5.5.5.5/32 routeable 0x1 [0] [0x0001:0x0003:0x0003] deny ip 0.0.0.0/0 0.0.0.0/0 routeable 0x1 [0]
Hi @mhiyoshi
Just to understand, you want to see the match counters per interface of an ACL applies on a SVI? That is not possible.
In the command you just used you see the counters per ASIC TCAM Instance.
You can try to use Port ACL with statistics per-entry enabled and apply the ACLs on the desired interfaces.
Stay safe,
Sergiu
Hi, thank you very much!
Yes, if ACL with statistics per-entry then it shows ACL counter like [XXX], however in case of interface vlan (SVI) with ACL,
If I configure with switchport access vlan [vlan-id] on several physical interface, it creates INSTANCE value like 0x0, 0x1 etc.
So it can be helpful if I can check which physical interface is related to the created INSTANCE value.
Best Regards,
Masanobu Hiyoshi
HI @mhiyoshi
Again, instance is just the TCAM (ASIC) instance. Is not the interface.
You only see the Instance the interface belong to.
Stay safe,
Sergiu
Hi msdaniluk,
Thank you very much.
