Hello all,
We have a pair of Nexus 5K, running 7.3(3)N1(1), with HSRP configured. HSRP is tracked, but we would like the hsrp to shutdown if the track condition is not satisfied. I see that the command "track x shutdown" under hsrp configuration is not present. Is hsrp shutdown feature not included in NX-OS? Is there a workaround to achieve the same result, like with EEM?
Is the limitation only for N5K, or do N7K with 8.3(2) have the same issue?
Thank you in advance,
Katerina
Hello
On first creation of the track in hsrp if you dont have this option then Its possible that this feature just isnt applicable in nxos, I couldn't find anything relating to fhrp group shutdown in CCO documentation for the 5-7ks either.
