ipInDiscards SNMP oid meaning for nexus switchs
Lewis7422
Dear community,
We are currently using a few 93180YC-EX Nexus switchs only for L2 traffic - propagating vlans to servers connected to this switchs. Our NMS did an auto discovery of SNMP oids for these nexus, and reported some warning for the ipInDiscards oid (1.3.6.1.2.1.4.8.0 - SNMP counters are increasing ) but i cannot find the meaning of this counter in the CLI.
I checked our discard counters with the "show interface counters errors" and did not found any discards.
Does someone know where to look or the mapping of this oid to the corresponding CLI commands ?
Thank you.
Dawei
Hi @Lewis7422 ,
I didn't find much information to describe it, but I think it may be related to "IP Software Processed Traffic Statistics". In general, the switch is forwarded by hardware, if it is a layer2 switch, you don’t need to worry about it.
N93180YC-EX# show ip traffic
default
Transmission and reception:
  Packets received: 138545, sent: 512, consumed: 4581,
  Forwarded, unicast: 0, multicast: 0, Label: 0
  Ingress mcec forward: 0
Opts:
  end: 0, nop: 0, basic security: 0, loose source route: 0
  timestamp: 0, ext. security: 0, record route: 0
  strict source route: 0, alert: 0,
  other: 0
Errors:
  Bad checksum: 0, packet too small: 0, bad version: 0,
  Bad header length: 0, bad packet length: 0, bad destination: 0,
  Bad ttl: 0, could not forward: 71811, no buffer dropped: 0,
  Bad encapsulation: 1, no route: 0, non-existent protocol: 0
  Bad options: 0
  Vinci Migration Packets : 0
   Total packet snooped : 0
   Total packet on down svi : 0
   Stateful Restart Recovery: 0,  MBUF pull up fail: 0
  Bad context id: 0, rpf drops: 0 Bad GW MAC 0
  Ingress option processing failed: 0
  NAT inside drop: 0, NAT outside drop: 0
  Ingress option processing failed: 0  Ingress mforward failed: 62153
  Ingress lisp drop: 0
  Ingress lisp decap drop: 0
  Ingress lisp encap drop: 0
  Ingress lisp encap: 0
  Ingress Mfwd copy drop: 0
  Ingress RA/Reass drop: 0
  Ingress ICMP Redirect processing drop: 0
  Ingress Drop (ifmgr init): 0,
  Ingress Drop (invalid filter): 0
  Ingress Drop (Invalid L2 msg): 0
  ACL Filter Drops :
       Ingress - 0
       Egress -   0
       Directed Broadcast - 0
Fragmentation/reassembly:
  Fragments received: 0, fragments sent: 0, fragments created: 0,
  Fragments dropped: 0, packets with DF: 0, packets reassembled: 0,
  Fragments timed out: 0
Fragments created per protocol
ICMP Software Processed Traffic Statistics
Transmission:
  Redirect: 0, unreachable: 0, echo request: 122, echo reply: 1,
  Mask request: 0, mask reply: 0, info request: 0, info reply: 0,
  Parameter problem: 0, source quench: 0, timestamp: 0,
  Timestamp response: 0, time exceeded: 0,
  Irdp solicitation: 0, irdp advertisement: 0
  Output Drops - badlen: 0, encap fail: 0, xmit fail: 0
  ICMP originate Req: 1, Redirects Originate Req: 0
  Originate deny - Resource fail: 0, short ip: 0, icmp: 0, others: 0
Reception:
  Redirect: 0, unreachable: 4184, echo request: 1, echo reply: 2,
  Irdp solicitation: 0, irdp advertisement: 0,
  Format error: 0, checksum error: 0
  Lisp processed: 0, No clients: 0: Consumed: 4187
  Replies: 2, Reply drops - bad addr: 0, inactive addr: 0
Statistics last reset: never
RFC 4293: IP Software Processed Traffic Statistics
Reception
  Pkts recv: 138545, Bytes recv: 23473085,
   inhdrerrors: 0, innoroutes: 0, inaddrerrors: 0,
   inunknownprotos: 0, intruncatedpkts: 0, inforwdgrams: 71811,
   reasmreqds: 0, reasmoks: 0, reasmfails: 0,
   indiscards: 0, indelivers: 4602,                     <<<<<<<<<<
   inmcastpkts: 62153, inmcastbytes: 4975999,
   inbcastpkts: 71811,
Transmission
  outrequests: 533, outnoroutes: 0, outforwdgrams: 0,
  outdiscards: 0, outfragreqds: 0, outfragoks: 0,
  outfragfails: 0, outfragcreates: 0, outtransmits: 512,
  bytes sent: 68629, outmcastpkts: 0, outmcastbytes: 0,
  outbcastpkts: 0, outbcastbytes: 0
Dawei
Hi @Lewis7422 ,
default
Opts:
  other: 0
Errors:
  Bad options: 0
  ACL Filter Drops :
       Ingress - 0
       Egress -   0
Transmission:
Reception:
Reception
   inbcastpkts: 71811,
Transmission
Thank you for your answer, yes this could be counter for software processed packets and in our case associated to our management trafic (we use an SVI for mgmt trafic and not the mgmt port so this could be related). As we do not see any problems regarding our traffic, we will delete this check.
Thank you.
