Hello @Tony JOrdan.
OTV is used in many production environments leveraging Cisco Nexus 7000 Switches or Cisco ASR 1000 Routers.
While indeed VXLAN can nowadays replace OTV, it is actually about choosing the right tool for the job.
VXLAN will perfectly serve as the DCI technology when using Cisco Nexus 9000 Switches deployed in the following architectures:
In these architectures, VXLAN is the overlay technology for intra and inter Data Center communication.
It is still worth the effort to dedicate some study time to properly understand OTV which you may find in existing network environments. Ultimately, a good grasp of OTV will help you to understand why VXLAN can take its place in newer architectures.
I hope this helps.
Best Regards.
