issues creating IVR zones in MDS 9710
Gilberto Marcos
Hello I hope some one can help.
We have several MDS switches in a customer network, recently they had to add more IVR zones, but when the customer try to add one new IVR zone
SAN12(config)# ivr zone name
IVR_mxoccsapcwd01_fcs2_new_MXOCCSTGSV1_SV2_N1P7_N2P14
Fabric is changing. Please retry the request later
We have check and we don't see any lock in the fabric.
Have someone has faced this issue?
Bhavin Yadav
Hi Gilberto,
Few things you can do but I would recommend opening Cisco TAC case for deeper troubleshooting on IVR.
This issue could be anything – past IVR / zoning config issues, or any other config issues. Following commands may help:
Check for any cfs or zoning locks: show cfs lock Show zone status | i VSAN|session
(session: none) means there are no zone locks Resolve any lock issues if they exist.
Option one: Configure ivr on new switch:
feature ivr
ivr nat
ivr distribute
Option two: Remove switch from the ivr config
ivr vsan-topology database no autonomous-fabric-id switch-wwn vsan-ranges
ivr vsan-topology activate
ivr commit
The above may help but otherwise, Cisco TAC is your best bet.
Hello Bhavin.
Thank you for your answer. Right now the MDS device don't have PSS support. The Customer project manager is working on that.
We have a troubleshooting session and we were able to notice the following trying to commit the ivr changes on the devices.
MXOCCSAN02(config)# sh ivr session status
Last Action Time Stamp     : Wed Dec  1 13:29:10 2021
Last Action                : Commit
Last Action Result         : Fail
Last Action Failure Reason : cfs(0x40b3002b)- Lock failed
MXOCCSAN04(config)# sh ivr session status
Last Action Time Stamp     : Wed Dec  1 13:10:13 2021
MXOCCSAN12(config)# sh ivr session status
Last Action Time Stamp     : Wed Dec  1 11:29:32 2021
Last Action Result         : Success
Last Action Failure Reason : none
Also we are trying to upgrade the MDS, but when checking for the instal all impact we got the following:
Notifying services about system upgrade.        [#                   ]   0% -- FAIL.
Service "zone" returned error: Zone change in progress, ISSU rejected. (0x402000EF)
Pre-upgrade check failed. Return code 0x402000EF (Zone change in progress, ISSU rejected.).
We try to find the lock trough the fabric and we did not find anything.
Have you face something like that?
