Issues pushing DCNM template to Nexus 9k switches
I have just deployed DNCM within a small greenfield DC environment. Thus far , I have been able to discover my switches and have them populate within my inventory of fabric switches. However, when I go in to actually push out my created fabric template I get an error:
Switch [ACCESS-SWITCH01/9YJFE8G3UO5]: Failed to get SSH connection. Please ensure LAN credentials and try save & deploy
I have confirmed that an active local user with the role of a vdc-operator lives on the switch and I have confirmed that the credentials match for the switch within DCNM, however I still receive this error. Would anyone know why this is happening. Just FYI, I am still fairly new to Nexus so I wouldn't be surprised if its be something very obvious that I am doing wrong.
Thanks!
9K Base Config:
!Time: Sun Oct 24 23:31:58 2021
version 7.0(3)I7(3)
hostname AGG-SWITCH02
vdc AGG-SWITCH02 id 1
limit-resource vlan minimum 16 maximum 4094
limit-resource vrf minimum 2 maximum 4096
limit-resource port-channel minimum 0 maximum 511
limit-resource u4route-mem minimum 248 maximum 248
limit-resource u6route-mem minimum 96 maximum 96
limit-resource m4route-mem minimum 58 maximum 58
limit-resource m6route-mem minimum 8 maximum 8
feature interface-vlan
no password strength-check
username admin password 5 $5$FA2mJGPr$K8HROWVyw6xvwLdWbryTNSORzqAdEXy9iQQ3YCYPRO
1 role network-admin
username admin role network-operator
username admin role priv-15
ip domain-lookup
snmp-server user admin network-admin auth sha 0x875becc1df9e3b0bbd6a0667f1fb93be
b3f5cc94 priv aes-128 0x875becc1df9e3b0bbd6a0667f1fb93beb3f5cc94 localizedkey
snmp-server user admin priv-15
snmp-server user admin network-operator
rmon event 1 description FATAL(1) owner PMON@FATAL
rmon event 2 description CRITICAL(2) owner PMON@CRITICAL
rmon event 3 description ERROR(3) owner PMON@ERROR
rmon event 4 description WARNING(4) owner PMON@WARNING
rmon event 5 description INFORMATION(5) owner PMON@INFO
vlan 1
vrf context management
interface Vlan1
no shutdown
ip address 10.0.101.248/24
interface Vlan200
no shutdown
ip address 10.0.200.248/24
Dawei
DCNM use SNMPv3 to discovery the switch and use SSH to push the configuration and. Did you check the Lan Credentials page for this switch?
You need to specify a default credentials here:
