ITD: Load Balancing, Traffic Steering and Clustering using Nexus 5k/6k/7k/9k
ssharma
ITD won the Best of Interop 2015 in Data Center Category.
ITD provides :
  1. Hardware based multi-terabit/s L3/L4 load-balancing at wire-speed.
  2. Zero latency load-balancing.
  3. CAPEX savings : No service module or external L3/L4 load-balancer needed. Every Nexus port can be used as load-balancer.
  4. Redirect line-rate traffic to any devices, for example web cache engines, Web Accelerator Engines (WAE), video-caches, etc.
  5. Capability to create clusters of devices, for example, Firewalls, Intrusion Prevention System (IPS), or Web Application Firewall (WAF), Hadoop cluster
  6. IP-stickiness
  7. Resilient (like resilient ECMP), Consistent hash
  8. VIP based L4 load-balancing
  9. NAT (available for EFT/PoC). Allows non-DSR deployments.
  10. Weighted load-balancing
  11. Load-balances to large number of devices/servers
  12. ACL along with redirection and load balancing simultaneously.
  13. Bi-directional flow-coherency. Traffic from A–>B and B–>A goes to same node.
  14. Order of magnitude OPEX savings : reduction in configuration, and ease of deployment
  15. Order of magnitude CAPEX savings : Wiring, Power, Rackspace and Cost savings
  16. The servers/appliances don’t have to be directly connected to Nexus switch
  17. Monitoring the health of servers/appliances.
  18. N + M redundancy.
  19. Automatic failure handling of servers/appliances.
  20. VRF support, vPC support, VDC support
  21. Supported on all linecards of Nexus 9k/7k/6k/5k series.
  22. Supports both IPv4 and IPv6
  23. Cisco Prime DCNM Support
  24. exclude access-list
  25. No certification, integration, or qualification needed between the devices and the Cisco NX-OS switch.
  26. The feature does not add any load to the supervisor CPU.
  27. ITD uses orders of magnitude less hardware TCAM resources than WCCP.
  28. Handles unlimited number of flows.
For example,
  • Load-balance traffic to 256 servers of 10Gbps each.
  • Load-balance to cluster of Firewalls. ITD is much superior than PBR.
  • Scale IPS, IDS and WAF by load-balancing to standalone devices.
  • Scale the NFV solution by load-balancing to low cost VM/container based NFV.
  • Scale the WAAS / WAE solution.
  • Scale the VDS-TC (video-caching) solution.
  • Scale the Layer-7 load-balancer, by distributing traffic to L7 LBs.
  • ECMP/Port-channel cause re-hashing of flows. ITD is resilient, and doesn't cause re-hashing on node add/delete/failure.
Documentation, slides, videos:
0 Replies 0
