01-03-2019 07:48 PM - edited 01-03-2019 07:50 PM
As fair as I know the connection between VDCs in N7K For example should be physical . And there is No leaking way internal .
the question is How the Admin VDC able to jumping between the VDCs? what is the
mechanism the NX-OS using for that ?
Solved! Go to Solution.
01-04-2019 06:23 AM
Hi there,
"The Admin VDC is a specialized VDC for administrative functions but also has a restriction that warrants mentioning. It is not possible to have an Ethernet interface allocated to the Admin VDC and it is not possible to have any L2 or L3 protocols in the Admin VDC. Admin VDC can be accessed only via the Console or Management ports on the Supervisor modules. No “inband” access via an interface, including loopbacks, can be configured. "
A great Chalk Talk regarding Nexus 7000 VDCs was provided here a few years ago -- Highly encourage going over it:
Hope that helps.
01-04-2019 12:52 AM
You can't allow front panel port to admin VDC, that's impossible.
01-04-2019 06:23 AM
Hi there,
Hope that helps.
01-04-2019 09:34 AM
Thank you that helps a lot.
01-15-2019 08:49 AM
01-15-2019 08:51 AM
NX-OS upgrades are chassis-wide only.
Thanks!
01-15-2019 09:01 AM - edited 01-15-2019 09:06 AM
So if I have an issue with one VDC which is I have now. (ARP with Tunnel interface issue related to IOS Bugs ) I have to stop all my business ( 5 VDCs ) just to fix this issue!!!
this is really big issue I think!
01-15-2019 09:11 AM
Nexus 7000/7700s support ISSU (In-Service Software Upgrades; assuming you have SUP redundancy). The chassis can be upgraded live with little to no disruption.
Understanding In-Service Software Upgrades
Cisco Nexus 7000 Series NX-OS Software Upgrade Guide
Thanks!
