Mapping tail drops to HIF port on 2232pp (woodside)
aches63
Beginner
Beginner
Hi!
I am trying to find out how to determine the tail drops on a host interface of a 2232pp fex. When you run the following commands:
attach fex xxx
fex-xxx# show platform software woodside ints
you get output like:
| SS0 : ssx_int_norm_td |
|0 |03cbe6de | tail drop[0] | frames are being tail dropped.
|1 |028cc71f | tail drop[1] | frames are being tail dropped.
|2 |03473782 | tail drop[2] | frames are being tail dropped.
|3 |022110c0 | tail drop[3] | frames are being tail dropped.
|8 |0000005a | tail drop[8] | frames are being tail dropped.
So SS0 (switching subsystem 0?) has tail drops. Ok, but what HIx interfaces are related to SS0 (or SS1, SS2 ... SS7)??
HI @aches63
On the woodside you only have 4 SS (sub systems). You can use the following command to check the Front port - HIF/NIF - SS relationship:
switch#  attach fex chassis_id
fex-[chassis_id]# show platform software woodside sts
fex-101# show platform software woodside sts
Board Status Overview:
 legend:
        '  '= no-connect
        X   = Failed
        -   = Disabled
        :   = Dn
        |   = Up
        .   = SFP waiting for t_start_up timer expiration
        i   = SFP waiting for prom info read
        c   = SFP waiting for t_start_up_cooled timer expiration
        *   = SFP present
        [X] = SFP validation failed
(FINAL POSITION TBD)     Uplink #:        1  2  3  4  5  6  7  8
                      Link status:        |  |  |  |  :  :  :  :
                              SFP:       [$][$][$][$][ ][ ][ ][ ]
                                        | N  N  N  N  N  N  N  N |
                                        | I  I  I  I  I  I  I  I |
                                        | 0  1  2  3  4  5  6  7 |
                                        |        NI (0-7)        |
|        HI (0-7)        | |        HI (8-15)       | |       HI (16-23)       | |        HI (24-31)      |
| H  H  H  H  H  H  H  H | | H  H  H  H  H  H  H  H | | H  H  H  H  H  H  H  H | | H  H  H  H  H  H  H  H |
| I  I  I  I  I  I  I  I | | I  I  I  I  I  I  I  I | | I  I  I  I  I  I  I  I | | I  I  I  I  I  I  I  I |
| 0  1  2  3  4  5  6  7 | | 8  9  1  1  1  1  1  1 | | 1  1  1  1  2  2  2  2 | | 2  2  2  2  2  2  3  3 |
|                        | |       0  1  2  3  4  5 | | 6  7  8  9  0  1  2  3 | | 4  5  6  7  8  9  0  1 |
  1  2  3  4  5  6  7  8     9  1  1  1  1  1  1  1     1  1  1  2  2  2  2  2     2  2  2  2  2  3  3  3
                                0  1  2  3  4  5  6     7  8  9  0  1  2  3  4     5  6  7  8  9  0  1  2
Legend:
Green = SS (sub system)
Blue = HIF port
Red = Front panel port
Another command which displays the SS - HIF/NIF only relationship is:
fex-101# show platform software woodside ss
             NI0-7   NI0-7    NI0-7    NI0-7
Read port     |        |        |        |
              V        V        V        V
           | SS0 |  | SS1 |  | SS2 |  | SS3 |
Write port |               NR               |
            HI0-7   HI8-15   HI16-23  HI24-31
           HI0-HI7  HI8-15   HI16-23  HI24-31
            V   V    V   V    V   V    V   V
           |               HR               |
                       V        V
                      NI0      NI7
In your case, as you have tail drops on SS0, you should simply move some cables from SS0 to other ports from other SS to avoid congestion. Easy way to see the current instant traffic rate on the ports is:
fex-101# show platform software woodside rate
Of course it would be best to check your NMS to see how the b/w utilization looks like on the rest of the ports.
Stay safe,
Sergiu
HI @aches63
 legend:
        '  '= no-connect
        X   = Failed
        -   = Disabled
        :   = Dn
        |   = Up
        *   = SFP present
                                        | N  N  N  N  N  N  N  N |
                                        | I  I  I  I  I  I  I  I |
                                        | 0  1  2  3  4  5  6  7 |
                                        |        NI (0-7)        |
Legend:
Blue = HIF port
Read port     |        |        |        |
              V        V        V        V
Write port |               NR               |
            V   V    V   V    V   V    V   V
           |               HR               |
                       V        V
                      NI0      NI7
Stay safe,
Sergiu
Thank you for the reply! When I run the show platform software woo new_ints command (after attach fex xxx), the output does show stats for SS4, SS5, SS6, and SS7. Are those names used to differentiate between the use of SS0, SS1, SS2, and SS3 for the NI ports or something else?
