MBGP redistribute/import between address families
rohandec1980
I have bgp ipv4 unicast neighborship with 2 WAN routers. I learn few bgp prefixes that i set community for.
I have a bgp ipv4 multicast peering with a firewall. I want to advertise prefixes learnt from the wan-router via address family ipv4 unicast into the mbgp ipv4 multicast family to the multicast firewall.
Can I redistribute/export routes between two addres familiies in MBGP?
Rohan
ChuckMcF
Without knowing specifics of your network and configurations it is difficult to know exactly how to answer your question however, from first glance, it looks like route leaking may be your answer. You can find my info in the attached link:
https://www.cisco.com/c/en/us/support/docs/ip/ip-routing/200158-Configure-Route-Leaking-between-Global-a.html
HTH,
Chuck McFadden
(please mark helpful posts as helpful)
