05-20-2022 09:15 AM
Hallo,
i have a project to migrate from Brocade switche to DS-C9148T-24PETK9 Switche.
The Server and Storgae are connected redudant to Fabric A and Fabric B.
We have 2 Data Center and in every Data Center i want to install 2 Switches.
Switche 1 in Data Center 1 connected to Switche 2 in Data Center 2
Switche 3 in Data Center 1 connected to Switche 4 in Data Center 2
The Distance between Data Center 1 and Data Center 2 is 181 Meter.
so i have to configure 2 Fabrics ( A and B ).
But this is the first time for me, so anyone could help me or advise me how i can configure them!
I wanna know how i will configure the Switche in Fabric A and Fabric B.....
Mercy
Jalo
05-20-2022 10:43 AM
05-22-2022 01:37 AM
Thanks so much for your help.
I have to do this config. after next week.
I wanna know just how to configure 2 switches in one fabric. Can you please provide me an example how i should do that?
when the tow swithces in one fabric, then i will see the 2 swithces as one logigal switch or they will be active/standby?
Thanks in advanced
Jalo
05-22-2022 06:35 AM
i read some Documentations and i found out that i should configure ISL Port channel ( E Type ) between 2 MDS Cisco Switche.
With this config can i have one Logical Switch?!
05-22-2022 09:54 AM
05-24-2022 12:31 AM
i will do this Config for example :
FC_switch_A_1# conf t FC_switch_A_1# shutdown FC_switch_A_1# switchport rate-mode dedicated FC_switch_A_1# switchport speed 8000 FC_switch_A_1# switchport fcrxbbcredit 60 FC_switch_A_1# switchport mode E FC_switch_A_1# switchport trunk mode on FC_switch_A_1# switchport trunk allowed vsan 10 FC_switch_A_1# switchport trunk allowed vsan add 20 FC_switch_A_1# channel-group 1 fc1/36 added to port-channel 1 and disabled FC_switch_B_1# conf t FC_switch_B_1# shutdown FC_switch_B_1# switchport rate-mode dedicated FC_switch_B_1# switchport speed 8000 FC_switch_B_1# switchport fcrxbbcredit 60 FC_switch_B_1# switchport mode E FC_switch_B_1# switchport trunk mode on FC_switch_B_1# switchport trunk allowed vsan 10 FC_switch_B_1# switchport trunk allowed vsan add 20 FC_switch_B_1# channel-group 1 fc1/36 added to port-channel 1 and disabled
The distance between Datacenters is 181 m, what i have to adjust here for distance ?
05-25-2022 01:43 AM
as i said i have now 6 Brocade Switche, each fabric has 3 Swithce. It is enough to take just the configuration from one switch in Fabric, or i have to take all the configuration from 3 Swithce in the fabric, und then i can convert them with Cisco Migration tool?
05-25-2022 05:15 PM
05-26-2022 01:58 AM
what do you mean with FID?
i have just one VSAN 1, if you mean this!
05-26-2022 10:20 AM
05-27-2022 02:58 AM
Ok, but for me just to know, if have more than one VSAN, which command shows me how many Fabrics IDs in Brocade and Cisco Switche?
05-27-2022 04:23 PM
05-26-2022 01:33 AM
ok Thanks...
after i run the migrated Config in Cisco Switche ( Principal switch ), should i have to configure the Ports as F Type for the Hosts and Tagets, or its all the config included in migrated config?
05-26-2022 10:23 AM
05-27-2022 03:00 AM
Durining initial Configuration one step is to configure the Ports as F Type
