11-18-2009 04:08 PM
Hi all,
I have a working nexus setup on two ESX hosts, with a VSM running on each host connected to a standard vSwitch. VEM is installed and working and its all good.
Mod Ports Module-Type Model Status
1 0 Virtual Supervisor Module Nexus1000V ha-standby
2 0 Virtual Supervisor Module Nexus1000V active *
3 248 Virtual Ethernet Module NA ok
4 248 Virtual Ethernet Module NA ok
We are now trying to move the two VSM's off the vSwitch and onto the distributed switch, but I must be doing something wrong! The VSM is setup with the following VLANs:
334 - Packet
335 - Control
990 - Management
When we move both hosts onto the distributed switch, one of the VSM's drops its connection to all the VEM's, and the 2nd one goes into a constant reboot cycle.
The configuration on the VSM is as follows:
ip host edpswvsmdmz001 10.193.26.250
vlan 334
name Packet
vlan 335
name Control
vlan 990
name Management
port-profile system-uplink
capability uplink
vmware port-group
switchport mode trunk
switchport trunk allowed vlan 334-335,990
channel-group auto mode on
no shutdown
system vlan 334-335,990
state enabled
port-profile trunk-uplink
capability uplink
vmware port-group
switchport trunk allowed vlan all
no shutdown
state enabled
port-profile nexus-packet-v334
vmware port-group
switchport mode access
switchport access vlan 334
no shutdown
state enabled
port-profile nexus-control-v335
vmware port-group
switchport access vlan 335
no shutdown
state enabled
port-profile nexus-management-v990
vmware port-group
switchport access vlan 990
no shutdown
state enabled
interface Ethernet3/2
inherit port-profile system-uplink
interface Ethernet3/4
inherit port-profile trunk-uplink
interface Ethernet4/2
interface Ethernet4/3
Now these are uplinked into a 3750.. the config on that is as follows:
interface Port-channel1
description vmh001-uplink
switchport nonegotiate
logging event trunk-status
logging event status
spanning-tree link-type point-to-point
end
interface Port-channel2
description vmh002-uplink
end
interface Port-channel11
description vmh001-system
switchport trunk allowed vlan 334,335,990
end
interface Port-channel12
description vmh002-system
Can anyone tell me what I am doing wrong here?
Cheers,
Mark
11-18-2009 05:32 PM
Are you moving one VSM at a time?
Move the standby VSM first, ensure they re-sync with "show sys red sta"
Then move the other one over.
Also, you did the right thing with making your control/packet/management vlans as "system" vlans on your System-Uplink, but you need to also configure system vlans on the Port Profiles you're assigning to your VSM interfaces. Missing config shown in RED
vmware port-group
system vlan 334
no shutdown
state enabled
vmware port-group
system vlan 335
no shutdown
state enabled
vmware port-group
system vlan 990
no shutdown
state enabled
Robert
11-18-2009 06:16 PM
Hi Robert... adding in those three lines fixed the problem.
I knew it would be something simple!
Thankyou so much for your assistance.
