multiple outside interfaces in asa1000v
maxwell207
asa 1000v default comes with 4 vnics management,inside,outside and HA.
Can I add another vnics and add interface in vnmc?
When i try to do that in vnmc web gui, i got error that vnmc allows only 1 inside and 1 outside.
The resason is to add another interface as dmz subnet and create site to site vpn.
admin11111
Level 4
Level 4
Datasheet still says only 2 usable are supported (inside & outside).  Agreed this is a limitation.  Press your account team.
Until then, you may need to use two of them in parallel or...
...you can tier them meaning 1 x FW and 1 x VPN with both of their inside interfaces terminating in LAN A.  LAN A would have another "edge" virtual FW with its outside interface in LAN A and its inside in another segment.  This requires 3 ASA 1000Vs.
-Jason
