ā02-11-2013 04:46 PM
I'm having issues with connectivity from my VSM to vCenter. I have active/standby VSM's. Every so often the connection from the VSM to vCenter drops off & later reconnects. The VEM's stay online and the VSM's stay online. There appears to be connectivity issues to the vCenter itself, i'm thinking it may be ssl/cert related but would appreciate a second opinion/advise.
Here are some log output, if someone could help me out as to what the issue may be it would be great.
Ray.
N1KV-PROD-VSM# sh logging last 30
2013 Feb 11 23:57:01 N1KV-PROD-VSM %VMS-3-DVS_UPDATE_ERROR: Unable to Update N1KV DVS in the VM
ware vCenterError: [VMware vCenter Server 5.0.0 build-623373] Operation could not be completed
due to connection failure.Timeout. SSL connect failed in tcp_connect()
2013 Feb 11 23:57:49 N1KV-PROD-VSM %VMS-5-CONN_DISCONNECT: Connection 'PROD-VC' disconnected fr
om the vCenter Server.
2013 Feb 12 00:00:49 N1KV-PROD-VSM %VMS-5-CONN_CONNECT: Connection 'PROD-VC' connected to the v
Center Server.
2013 Feb 12 00:02:09 N1KV-PROD-VSM %VMS-5-CONN_DISCONNECT: Connection 'PROD-VC' disconnected fr
2013 Feb 12 00:05:40 N1KV-PROD-VSM %VMS-5-CONN_CONNECT: Connection 'PROD-VC' connected to the v
Center Server.
2013 Feb 12 00:06:50 N1KV-PROD-VSM %VSHD-5-VSHD_SYSLOG_CONFIG_I: Configured from vty by admin o
n 157.190.4.113@pts/0
2013 Feb 12 00:07:14 N1KV-PROD-VSM %VMS-3-DVS_UPDATE_ERROR: Unable to Update N1KV DVS in the VM
2013 Feb 12 00:08:12 N1KV-PROD-VSM %VMS-5-CONN_DISCONNECT: Connection 'PROD-VC' disconnected fr
2013 Feb 12 00:11:12 N1KV-PROD-VSM %VMS-5-CONN_CONNECT: Connection 'PROD-VC' connected to the v
Center Server.
2013 Feb 12 00:11:43 N1KV-PROD-VSM %VMS-3-DVS_UPDATE_ERROR: Unable to Update N1KV DVS in the VM
2013 Feb 12 00:13:54 N1KV-PROD-VSM %MSP-5-DOMAIN_CFG_SYNC_DONE: Domain config successfully push
ed to the management server.
2013 Feb 12 00:14:26 N1KV-PROD-VSM %VMS-3-DVS_UPDATE_ERROR: Unable to Update N1KV DVS in the VM
2013 Feb 12 00:14:26 N1KV-PROD-VSM %VMS-3-CONNECTION_ERROR: Unable to communicate with vCenter
Server/ESX. Disconnecting..
2013 Feb 12 00:14:26 N1KV-PROD-VSM %VMS-5-CONN_DISCONNECT: Connection 'PROD-VC' disconnected fr
2013 Feb 12 00:14:26 N1KV-PROD-VSM %MSP-5-PP_UPDATE_FAILED: Update of port-profile 'MGMT_Uplink
' on the vCenter Server failed. Please verify port-profile config.
2013 Feb 12 00:14:26 N1KV-PROD-VSM %MSP-5-PP_UPDATE_FAILED: Update of port-profile 'Unused_Or_Q
uarantine_Uplink' on the vCenter Server failed. Please verify port-profile config.
2013 Feb 12 00:14:26 N1KV-PROD-VSM %MSP-5-PP_UPDATE_FAILED: Update of port-profile 'VM_Data_Upl
2013 Feb 12 00:14:26 N1KV-PROD-VSM %MSP-5-PP_UPDATE_FAILED: Update of port-profile 'V_L3_CONTRO
L_99' on the vCenter Server failed. Please verify port-profile config.
2013 Feb 12 00:14:26 N1KV-PROD-VSM %VMS-5-CONN_CONNECT: Connection 'PROD-VC' connected to the v
Center Server.
2013 Feb 12 00:16:34 N1KV-PROD-VSM %VMS-5-CONN_DISCONNECT: Connection 'PROD-VC' disconnected fr
2013 Feb 12 00:20:24 N1KV-PROD-VSM %VMS-5-CONN_CONNECT: Connection 'PROD-VC' connected to the v
Center Server.
2013 Feb 12 00:21:42 N1KV-PROD-VSM %VSHD-5-VSHD_SYSLOG_CONFIG_I: Configured from vty by admin o
2013 Feb 12 00:22:49 N1KV-PROD-VSM %VMS-3-DVS_UPDATE_ERROR: Unable to Update N1KV DVS in the VM
due to connection failure.End of file or no input: Operation interrupted or timed out after 160
s send or 160s receive delay.
2013 Feb 12 00:23:40 N1KV-PROD-VSM %VMS-5-CONN_DISCONNECT: Connection 'PROD-VC' disconnected fr
2013 Feb 12 00:23:40 N1KV-PROD-VSM %VMS-5-CONN_CONNECT: Connection 'PROD-VC' connected to the v
Center Server.
2013 Feb 12 00:25:49 N1KV-PROD-VSM %VMS-3-DVS_UPDATE_ERROR: Unable to Update N1KV DVS in the VM
2013 Feb 12 00:25:53 N1KV-PROD-VSM %VMS-5-CONN_DISCONNECT: Connection 'PROD-VC' disconnected fr
2013 Feb 12 00:28:52 N1KV-PROD-VSM %VSHD-5-VSHD_SYSLOG_CONFIG_I: Configured from vty by admin o
2013 Feb 12 00:28:53 N1KV-PROD-VSM %VMS-5-CONN_CONNECT: Connection 'PROD-VC' connected to the v
Center Server.
2013 Feb 12 00:29:57 N1KV-PROD-VSM %VMS-5-CONN_DISCONNECT: Connection 'PROD-VC' disconnected fr
N1KV-PROD-VSM#
N1KV-PROD-VSM#
N1KV-PROD-VSM# sh vms internal event-history errors
1) Event:E_DEBUG, length:53, at 431472 usecs after Tue Feb 12 00:34:05 2013
[102] waitForTask(5968): Error in creating Task filter
2) Event:E_DEBUG, length:216, at 431466 usecs after Tue Feb 12 00:34:05 2013
[102] convert_soap_fault_to_err(1858): SOAP 1.1 fault: SOAP-ENV:Client [VMware vCenter Serv
er 5.0.0 build-623373] Operation could not be completed due to connection failure.Timeout. SSL
3) Event:E_DEBUG, length:49, at 431422 usecs after Tue Feb 12 00:34:05 2013
[102] createFilter(5838): Error in creating filter
4) Event:E_DEBUG, length:103, at 662124 usecs after Tue Feb 12 00:33:33 2013
[102] sf_mgmt_srv_lib_update_dvswitch(1434): updating dvs by switch uuid failed. Sending sy
slog message.
5) Event:E_DEBUG, length:83, at 662117 usecs after Tue Feb 12 00:33:33 2013
[102] updateDVSBySwitchUUID(3907): failed to retrieve dvs info by uuid. returning -1
6) Event:E_DEBUG, length:216, at 662112 usecs after Tue Feb 12 00:33:33 2013
7) Event:E_DEBUG, length:77, at 662090 usecs after Tue Feb 12 00:33:33 2013
[102] getDVSInfoBySwitchUUID(4200): failed to get object properties. returning
8) Event:E_DEBUG, length:216, at 662076 usecs after Tue Feb 12 00:33:33 2013
9) Event:E_DEBUG, length:57, at 662033 usecs after Tue Feb 12 00:33:33 2013
[102] getObjectProperties(2344): RetrieveProperties failed
10) Event:E_DEBUG, length:81, at 322004 usecs after Tue Feb 12 00:33:00 2013
[102] sf_mgmt_srv_get_all_dvpgs(393): dvs = null or no dvpgs exist. returning fail
11) Event:E_DEBUG, length:69, at 321922 usecs after Tue Feb 12 00:33:00 2013
[102] vms_connect(1837): Failed to remove visibility role (0x41b1000c)
12) Event:E_DEBUG, length:106, at 321805 usecs after Tue Feb 12 00:33:00 2013
[102] vms_vim_delete_visibility_role(3741): Error occurred while searching for visibility r
ole (0x41b1000c)
13) Event:E_DEBUG, length:104, at 321800 usecs after Tue Feb 12 00:33:00 2013
[102] convert_soap_fault_to_err(1858): SOAP 1.1 fault: (null) [VMware vCenter Server 5.0.0
build-623373]
14) Event:E_DEBUG, length:216, at 342035 usecs after Tue Feb 12 00:29:57 2013
15) Event:E_DEBUG, length:60, at 342013 usecs after Tue Feb 12 00:29:57 2013
[102] waitForTask(6001): ERROR in Retreiving taskInfo from VC
16) Event:E_DEBUG, length:216, at 342005 usecs after Tue Feb 12 00:29:57 2013
17) Event:E_DEBUG, length:216, at 341974 usecs after Tue Feb 12 00:29:57 2013
18) Event:E_DEBUG, length:57, at 341923 usecs after Tue Feb 12 00:29:57 2013
19) Event:E_DEBUG, length:216, at 81730 usecs after Tue Feb 12 00:29:25 2013
20) Event:E_DEBUG, length:84, at 81708 usecs after Tue Feb 12 00:29:25 2013
[102] getDVPortgroupInfo(4280): failed to get object properties for pg mor. returning
21) Event:E_DEBUG, length:216, at 81693 usecs after Tue Feb 12 00:29:25 2013
22) Event:E_DEBUG, length:57, at 81648 usecs after Tue Feb 12 00:29:25 2013
23) Event:E_DEBUG, length:81, at 794658 usecs after Tue Feb 12 00:28:53 2013
24) Event:E_DEBUG, length:103, at 893290 usecs after Tue Feb 12 00:25:49 2013
slog message.
25) Event:E_DEBUG, length:81, at 872872 usecs after Tue Feb 12 00:25:49 2013
[102] waitForTask(5983): Failed to wait for updates on the Task. UpdateSet is NULL
26) Event:E_DEBUG, length:271, at 872863 usecs after Tue Feb 12 00:25:49 2013
[102] convert_soap_fault_to_err(1858): Error -1 fault: SOAP-ENV:Client [VMware vCenter Serv
er 5.0.0 build-623373] Operation could not be completed due to connection failure.End of file o
r no input: Operation interrupted or timed out after 160s send or 160s receive delay.
27) Event:E_DEBUG, length:54, at 872795 usecs after Tue Feb 12 00:25:49 2013
[102] waitForUpdates(5909): ERROR: in WaitForUpdates...
28) Event:E_DEBUG, length:81, at 872468 usecs after Tue Feb 12 00:25:49 2013
[102] vms_dequeue: (Error) SYSERR_FU_xx: 0x10, err_num (16) in fu_priority_select
29) Event:E_DEBUG, length:81, at 872140 usecs after Tue Feb 12 00:25:49 2013
30) Event:E_DEBUG, length:271, at 869803 usecs after Tue Feb 12 00:24:59 2013
31) Event:E_DEBUG, length:84, at 869779 usecs after Tue Feb 12 00:24:59 2013
32) Event:E_DEBUG, length:271, at 869764 usecs after Tue Feb 12 00:24:59 2013
33) Event:E_DEBUG, length:57, at 869692 usecs after Tue Feb 12 00:24:59 2013
34) Event:E_DEBUG, length:81, at 482043 usecs after Tue Feb 12 00:24:11 2013
35) Event:E_DEBUG, length:69, at 481930 usecs after Tue Feb 12 00:24:11 2013
[102] vms_connect(1837): Failed to remove visibility role (0x41b1000d)
36) Event:E_DEBUG, length:106, at 481876 usecs after Tue Feb 12 00:24:11 2013
ole (0x41b1000d)
37) Event:E_DEBUG, length:216, at 481870 usecs after Tue Feb 12 00:24:11 2013
38) Event:E_DEBUG, length:216, at 481827 usecs after Tue Feb 12 00:24:11 2013
39) Event:E_DEBUG, length:57, at 481785 usecs after Tue Feb 12 00:24:11 2013
40) Event:E_DEBUG, length:271, at 867776 usecs after Tue Feb 12 00:23:39 2013
41) Event:E_DEBUG, length:60, at 867753 usecs after Tue Feb 12 00:23:39 2013
42) Event:E_DEBUG, length:271, at 867746 usecs after Tue Feb 12 00:23:39 2013
43) Event:E_DEBUG, length:271, at 867713 usecs after Tue Feb 12 00:23:39 2013
44) Event:E_DEBUG, length:57, at 867637 usecs after Tue Feb 12 00:23:39 2013
45) Event:E_DEBUG, length:103, at 865970 usecs after Tue Feb 12 00:22:49 2013
slog message.
46) Event:E_DEBUG, length:271, at 865958 usecs after Tue Feb 12 00:22:49 2013
47) Event:E_DEBUG, length:71, at 865876 usecs after Tue Feb 12 00:22:49 2013
[102] updateDVSBySwitchUUID(3945): DVSPerformProductSpecOperation failed
48) Event:E_DEBUG, length:271, at 866456 usecs after Tue Feb 12 00:21:59 2013
49) Event:E_DEBUG, length:84, at 866432 usecs after Tue Feb 12 00:21:59 2013
50) Event:E_DEBUG, length:271, at 866418 usecs after Tue Feb 12 00:21:59 2013
51) Event:E_DEBUG, length:57, at 866345 usecs after Tue Feb 12 00:21:59 2013
52) Event:E_DEBUG, length:81, at 694641 usecs after Tue Feb 12 00:20:24 2013
53) Event:E_DEBUG, length:81, at 868900 usecs after Tue Feb 12 00:17:24 2013
54) Event:E_DEBUG, length:81, at 865742 usecs after Tue Feb 12 00:16:34 2013
55) Event:E_DEBUG, length:271, at 872408 usecs after Tue Feb 12 00:15:44 2013
56) Event:E_DEBUG, length:84, at 872390 usecs after Tue Feb 12 00:15:44 2013
57) Event:E_DEBUG, length:271, at 872378 usecs after Tue Feb 12 00:15:44 2013
58) Event:E_DEBUG, length:57, at 872324 usecs after Tue Feb 12 00:15:44 2013
59) Event:E_DEBUG, length:81, at 701396 usecs after Tue Feb 12 00:14:26 2013
60) Event:E_DEBUG, length:69, at 701325 usecs after Tue Feb 12 00:14:26 2013
61) Event:E_DEBUG, length:106, at 701209 usecs after Tue Feb 12 00:14:26 2013
ole (0x41b1000c)
62) Event:E_DEBUG, length:104, at 701205 usecs after Tue Feb 12 00:14:26 2013
build-623373]
63) Event:E_DEBUG, length:86, at 564869 usecs after Tue Feb 12 00:14:26 2013
[102] vms_ppm_sync_notify_cback(3897): No active connection to vc to update opaque data
64) Event:E_DEBUG, length:103, at 511811 usecs after Tue Feb 12 00:14:26 2013
slog message.
65) Event:E_DEBUG, length:81, at 471724 usecs after Tue Feb 12 00:14:26 2013
66) Event:E_DEBUG, length:216, at 471716 usecs after Tue Feb 12 00:14:26 2013
67) Event:E_DEBUG, length:54, at 471679 usecs after Tue Feb 12 00:14:26 2013
68) Event:E_DEBUG, length:102, at 285651 usecs after Tue Feb 12 00:13:55 2013
[102] sf_mgmt_srv_updt_port_profile_desc(656): sf_mgmt_srv_lib_updt_dv_port_profile failed.
return fail
69) Event:E_DEBUG, length:226, at 266924 usecs after Tue Feb 12 00:13:55 2013
[102] populate_err_with_vcinfo(732): ERROR: [VMware vCenter Server 5.0.0 build-623373] Ca
nnot set number of ports to 0 because at least 4 out of 4 ports are still in use. A specified p
arameter was not correct.
spec.numPorts.
70) Event:E_DEBUG, length:88, at 266909 usecs after Tue Feb 12 00:13:55 2013
[102] isTaskComplete(6077): ERROR: A specified parameter was not correct.
spec.numPorts
71) Event:E_DEBUG, length:104, at 897254 usecs after Tue Feb 12 00:13:04 2013
build-623373]
72) Event:E_DEBUG, length:271, at 841526 usecs after Tue Feb 12 00:13:04 2013
73) Event:E_DEBUG, length:271, at 841496 usecs after Tue Feb 12 00:13:04 2013
74) Event:E_DEBUG, length:57, at 841424 usecs after Tue Feb 12 00:13:04 2013
75) Event:E_DEBUG, length:70, at 751467 usecs after Tue Feb 12 00:12:15 2013
[102] vms_vim_rename_dvs_folder(3144): RenameDVSFolder operation failed
76) Event:E_DEBUG, length:39, at 751445 usecs after Tue Feb 12 00:12:15 2013
[102] Rename(2849): Rename Task failed
77) Event:E_DEBUG, length:103, at 651647 usecs after Tue Feb 12 00:11:43 2013
slog message.
78) Event:E_DEBUG, length:83, at 651640 usecs after Tue Feb 12 00:11:43 2013
79) Event:E_DEBUG, length:216, at 651634 usecs after Tue Feb 12 00:11:43 2013
80) Event:E_DEBUG, length:77, at 651612 usecs after Tue Feb 12 00:11:43 2013
81) Event:E_DEBUG, length:216, at 651598 usecs after Tue Feb 12 00:11:43 2013
82) Event:E_DEBUG, length:57, at 651556 usecs after Tue Feb 12 00:11:43 2013
83) Event:E_DEBUG, length:81, at 277011 usecs after Tue Feb 12 00:11:12 2013
84) Event:E_DEBUG, length:69, at 276931 usecs after Tue Feb 12 00:11:12 2013
85) Event:E_DEBUG, length:106, at 276817 usecs after Tue Feb 12 00:11:12 2013
ole (0x41b1000c)
86) Event:E_DEBUG, length:104, at 276813 usecs after Tue Feb 12 00:11:12 2013
build-623373]
87) Event:E_DEBUG, length:70, at 232084 usecs after Tue Feb 12 00:07:46 2013
[102] performDVSProductSpecOperation(5490): Couldn't retrieve bundleId
88) Event:E_DEBUG, length:65, at 232079 usecs after Tue Feb 12 00:07:46 2013
[102] getDVSBundleId(5322): coudn't retrieve bundleID. return null
89) Event:E_DEBUG, length:216, at 232068 usecs after Tue Feb 12 00:07:46 2013
90) Event:E_DEBUG, length:57, at 232014 usecs after Tue Feb 12 00:07:46 2013
91) Event:E_DEBUG, length:103, at 521862 usecs after Tue Feb 12 00:07:14 2013
slog message.
92) Event:E_DEBUG, length:83, at 521848 usecs after Tue Feb 12 00:07:14 2013
93) Event:E_DEBUG, length:216, at 521829 usecs after Tue Feb 12 00:07:14 2013
94) Event:E_DEBUG, length:77, at 521807 usecs after Tue Feb 12 00:07:14 2013
95) Event:E_DEBUG, length:216, at 521793 usecs after Tue Feb 12 00:07:14 2013
96) Event:E_DEBUG, length:57, at 521752 usecs after Tue Feb 12 00:07:14 2013
97) Event:E_DEBUG, length:216, at 401892 usecs after Tue Feb 12 00:06:43 2013
98) Event:E_DEBUG, length:84, at 401869 usecs after Tue Feb 12 00:06:43 2013
99) Event:E_DEBUG, length:216, at 401855 usecs after Tue Feb 12 00:06:43 2013
100) Event:E_DEBUG, length:57, at 401812 usecs after Tue Feb 12 00:06:43 2013
101) Event:E_DEBUG, length:81, at 56168 usecs after Tue Feb 12 00:06:12 2013
102) Event:E_DEBUG, length:69, at 55988 usecs after Tue Feb 12 00:06:12 2013
103) Event:E_DEBUG, length:106, at 55827 usecs after Tue Feb 12 00:06:12 2013
ole (0x41b1000c)
104) Event:E_DEBUG, length:104, at 55821 usecs after Tue Feb 12 00:06:12 2013
build-623373]
105) Event:E_DEBUG, length:83, at 962201 usecs after Tue Feb 12 00:06:11 2013
[102] vms_vim_create_host_filter(2456): Failed to create a filter with the host spec
106) Event:E_DEBUG, length:216, at 962195 usecs after Tue Feb 12 00:06:11 2013
107) Event:E_DEBUG, length:49, at 962148 usecs after Tue Feb 12 00:06:11 2013
108) Event:E_DEBUG, length:81, at 801167 usecs after Tue Feb 12 00:02:09 2013
109) Event:E_DEBUG, length:271, at 799785 usecs after Tue Feb 12 00:02:09 2013
110) Event:E_DEBUG, length:60, at 799762 usecs after Tue Feb 12 00:02:09 2013
111) Event:E_DEBUG, length:271, at 799754 usecs after Tue Feb 12 00:02:09 2013
N1KV-PROD-VSM# sh module
Mod Ports Module-Type Model Status
1 0 Virtual Supervisor Module Nexus1000V active *
2 0 Virtual Supervisor Module Nexus1000V ha-standby
3 248 Virtual Ethernet Module NA ok
4 248 Virtual Ethernet Module NA ok
5 248 Virtual Ethernet Module NA ok
6 248 Virtual Ethernet Module NA ok
Mod Sw Hw
1 4.2(1)SV2(1.1) 0.0
2 4.2(1)SV2(1.1) 0.0
3 4.2(1)SV2(1.1) VMware ESXi 5.0.0 Releasebuild-474610 (3.0)
4 4.2(1)SV2(1.1) VMware ESXi 5.0.0 Releasebuild-469512 (3.0)
5 4.2(1)SV2(1.1) VMware ESXi 5.0.0 Releasebuild-474610 (3.0)
6 4.2(1)SV2(1.1) VMware ESXi 5.0.0 Releasebuild-474610 (3.0)
N1KV-PROD-VSM# 2013 Feb 12 00:36:34 N1KV-PROD-VSM %VMS-3-DVS_UPDATE_ERROR: Unable to Update N1KV DVS in the VMware vCenterError: [VMware vCenter Server 5.0.0 build-623373] Operation could not be completed due to connection failure.End of file or no input: Operation interrupted or timed out after 160s send or 160s receive delay.
2013 Feb 12 00:36:34 N1KV-PROD-VSM %VMS-3-CONNECTION_ERROR: Unable to communicate with vCenter Server/ESX. Disconnecting..
2013 Feb 12 00:36:34 N1KV-PROD-VSM %VMS-5-CONN_DISCONNECT: Connection 'PROD-VC' disconnected from the vCenter Server.
2013 Feb 12 00:36:35 N1KV-PROD-VSM %MSP-5-PP_UPDATE_FAILED: Update of port-profile 'MGMT_Uplink' on the vCenter Server failed. Please verify port-profile config.
2013 Feb 12 00:36:35 N1KV-PROD-VSM %MSP-5-PP_UPDATE_FAILED: Update of port-profile 'Unused_Or_Quarantine_Uplink' on the vCenter Server failed. Please verify port-profile config.
2013 Feb 12 00:36:35 N1KV-PROD-VSM %MSP-5-PP_UPDATE_FAILED: Update of port-profile 'VM_Data_Uplink' on the vCenter Server failed. Please verify port-profile config.
2013 Feb 12 00:36:35 N1KV-PROD-VSM %MSP-5-PP_UPDATE_FAILED: Update of port-profile 'V_L3_CONTROL_99' on the vCenter Server failed. Please verify port-profile config.
2013 Feb 12 00:36:35 N1KV-PROD-VSM %VMS-5-CONN_CONNECT: Connection 'PROD-VC' connected to the vCenter Server.
2013 Feb 12 00:37:37 N1KV-PROD-VSM %VMS-3-DVS_UPDATE_ERROR: Unable to Update N1KV DVS in the VMware vCenterError: Error in creating Task filter
N1KV-PROD-VSM#
N1KV-PROD-VSM# 2013 Feb 12 00:38:09 N1KV-PROD-VSM %VMS-5-CONN_DISCONNECT: Connection 'PROD-VC' disconnected from the vCenter Server.
N1KV-PROD-VSM# sh svs connections
connection PROD-VC:
ip address: 192.168.10.10
remote port: 80
protocol: vmware-vim https
certificate: default
datacenter name: CIT
admin:
max-ports: 8192
DVS uuid: 57 b5 01 50 b3 f6 66 b4-e1 be a3 2a 97 4a f2 11
config status: Enabled
operational status: Disconnected
sync status: -
version: -
vc-uuid: -
N1KV-PROD-VSM# sh svs domain
SVS domain config:
Domain id: 30
Control vlan: NA
Packet vlan: NA
L2/L3 Control mode: L3
L3 control interface: mgmt0
Status: Config push to VC successful.
Control type multicast: No
Note: Control VLAN and Packet VLAN are not used in L3 mode
N1KV-PROD-VSM#
ā02-12-2013 05:17 AM
I got this one sorted, Turned out to be a sub-optimal routing issue between the N1kv MGMT & vCenter affecting the SVS connection. I shutdown one of our L2/L3 links out from our UCS/N5K systems to an area where vCenter was in production and it stabilised. Just need to fix it now and re-activate the link.
No connection drop off's since this.
Hopefully this may assist someone who sees this type of behaviour in the future,
Ray.
ā07-11-2013 06:06 AM
Please provide additional details about the underlying issue and the fix you were able to implement. Thanks.
ā07-19-2015 04:39 PM
Hello Raymond,
Can you please help me understand what you mean by "I shutdown one of our L2/L3 links out from our UCS/N5K systems to an area where vCenter was in production and it stabilised. Just need to fix it now and re-activate the link."
Thank you.
With regards,
Nithin.
ā11-10-2014 11:31 AM
I am seeijnt this on VSphere 5.5 and I have no idea how to resolve or troubleshoot.
Any help would be most welcome. Below are the log messages.
