N1Kv and memory requirements
paul snoep
From the Q&A Nexus 1000V below an excerpt of the requirements on ESXi. What I wonder, when I have 50 VEMS (or 50 physical hosts) do I need 2G memory (VSM) and 50*150M or 7.5G for the VEMs, so total 9.5G? Or does the 150M sit as process in the physical hosts?
Paul
Q. What are the system requirements?
A. System requirements are as follows:
• Works with all switching architectures
• Cisco Nexus 1000V VSM
– VMware vSphere Enterprise Plus Version 4.0 or later
– Can be deployed as a virtual machine on VMware ESX 3.5 or 4
– Hard disk: 3 GB
– RAM: 2 GB
– One virtual CPU at 1 GHz
• Cisco Nexus 1000V VEM
– VMware vSphere Enterprise Plus version 4.0 or later
– Hard disk space: 6.5 MB
– RAM: 150 MB
manir
Hi Paul,
You would be needing only 2GB for VSM, and 150 MB for VEM mentioned will be on each physical hosts.
Manikanta
manir
Hi Paul,
Manikanta
