04-06-2021 01:55 PM
Greetings,
Please let me know if I should replace the N3K-C3548P-10G with N3K-C3548P-10GX or is it better go to the Catalyst 9000 series then moving away from Nexus.
Edouard.
Solved! Go to Solution.
04-07-2021 02:50 AM
Hi Edouard,
Nexus 3500 is an ultra low latency switch, dedicated for Data Centers, for applications which are very sensitive to latency (trading, media streaming etc). Catalyst 9000 is a campus oriented device.
If you have a DC, you can compare the available Nexus platforms: https://www.cisco.com/c/en/us/products/switches/nexus-9000-series-switches/models-comparison.html
Depending on the environment you have, you can choose the one that suits your needs best.
Stay safe,
Sergiu
04-07-2021 02:50 AM
Hi Edouard,
Stay safe,
Sergiu
