N5K fex switch places and number
lightda
Frequent Visitor
Frequent Visitor
Hi, does anyone done with two fex switching change places and number?
For example:
I got two fex model: N2K-C2348UPQ & N2K-C2232PP, these two model was separate in different racks,
Nexus-5696# show fex
FEX                     FEX                    FEX                           FEX
Number        Description              State                        Model
121               FEX0121               Online             N2K-C2348UPQ-10GE
122               FEX0122               Online             N2K-C2232PP-10GE
now I wanted to switch this two model's racks and fex number with it without moving any cables.
So in my understanding, I should copy/backup the config of these two fex model before disassociate fex,
then move it to new fex port.
Am I right about this? Or is there better way to do?
Mark Elsen
 - You should save the running configuration of the parent switch ; when the fex are replaced ,port numbers appear again in order as to the first fex that comes online , map the and or configure the ports according to the previously saved port data from the (previous) running configuration ,
 M.
-- Let everything happen to you
       Beauty and terror
      Just keep going
       No feeling is final
Reiner Maria Rilke (1899)
Mark Elsen
 M.
       Beauty and terror
      Just keep going
       No feeling is final
