N7K: %DAEMON-2-SYSTEM_MSG: fatal: no hostkey alg.
CHISHIUNG
The Nexus switch outputs the following log once every few months. The source IPv6 address is from overseas, but it looks as if it is trying to make an SSH connection from the outside and failing.
Should I block it with an ACL?
%DAEMON-2-SYSTEM_MSG: fatal: no hostkey alg. Connection from xxxx:xxxx::xxxx:xxxx:xxxx:xxxx. client list =ecdsa-sha2-nistp256.ecdsa2-nistp384,ecdsa-sha2-nistp521 server list = ssh-rsa - dcos_sshd
marce1000
                  -  FYI  : https://bst.cloudapps.cisco.com/bugsearch/bug/CSCtx21848
           The outsider is  trying to make an SSH connection but no matching SSH algorithm could be found,
           good plan to block with ACL,
  N,
marce1000
  N,
