Need Help with Nexus Switch
mabuzaid1
Dear Community Members ,
Thanks for all of you who have been supported through the years as i have used the support community frequently .
As of now i am a new into Nexus switch .
My scnario is (is very critical for me to do the configuration )
we have:
N9K-C9348GC-FXP qty =2.
N9K-C93180YC-FX qty=2.
one Firewall routed to internet and connected with nexus switch .
What are the confiuration  needed , knowing that we have only a single vlan on the network (vlan 5) that needed to be routed to firewall (internet).
I know that this kind of general question but i dont know what to do .
Note switches are connected with its same model as VSS and to other switch using etherchannel .
Will be eagerly waiting for your help
Mansour
2 Accepted Solutions
Below the design updated
I haven't put the management interfaces on this design. I assume you connected your Nexus management interface to an OOB switch (or any switch) and subnet used for OOB is 192.168.99.0/24.
I will also create a vlan 10 L3 interface with HSRP to show how to do it in the default vrf.
These configs are a sample to show you how to do a simple config but I highly recommend you take a look at Cisco documentations.
Configuration of N9K-1 to build vpc peer-link (and related config).
feature lacp
feature vpc
vlan 10
name test-vlan-10
vlan 20
name test-vlan-20
vlan 30
name test-vlan-30
vlan 40
name test-vlan-40
vrf context management
ip route 0.0.0.0/0 192.168.99.1
interface mgmt0
vrf member management
ip address 192.168.99.247/24
vpc domain 1
peer-switch
role priority 20
peer-keepalive destination 192.168.99.248 source 192.168.99.247 vrf management
delay restore 150
peer-gateway
auto-recovery reload-delay 360
ip arp synchronize
spanning-tree vlan vlan-range priority 4096
interface Ethernet1/1
switchport
switchport mode trunk
channel-group 1 mode active
no shutdown
interface Ethernet1/2
switchport
no shutdown
interface port-channel1
switchport
spanning-tree port type network
vpc peer-link
int vlan 10
ip address 10.10.10.2/24
hsrp 10
ip 10.10.10.1
preempt
priority 105
no shut
Configuration of N9K-2 to build vpc peer-link (and related config).
feature lacp
feature vpc
vlan 10
name test-vlan-10
vlan 20
name test-vlan-20
vlan 30
name test-vlan-30
vlan 40
name test-vlan-40
interface mgmt0
ip address 192.168.99.248/24
vpc domain 1
peer-switch
role priority 40
peer-keepalive destination 192.168.99.247 source 192.168.99.248 vrf management
delay restore 150
peer-gateway
ip arp synchronize
switchport
channel-group 2 mode active
no shutdown
switchport
no shutdown
interface port-channel2
switchport
vpc peer-link
int vlan 100
ip address 10.10.10.3/24
hsrp 10
ip 10.10.10.1
preempt
no shut
For N9K-3 and N9K-4, you could do the same as previously but you need to change their management IPs and adapt it into the vpc domain section. Also you need to use another vpc domain. For example N9K-1 and 2 are using VPC domain 1, so use VPC-domain 2.  You will also have to change the spanning-tree priority. Instead of 4096, put 8192 on the config to N9K-3 & 4.
L3 interface can be created on N9K-3 & 4 but not mandatory, depends where you want to do routing.
You see there're are some VPCs.
Below how to create a VPC. I'll do it for 1 and let you apply the same logic for others:
Let's configure VPC 10 on N9K-1 & 2.
N9K-1:
interface E1/3
switchport
channel-group 10 mode active
interface E1/4
switchport
interface port-channel 10
switchport
vpc 10
N9K-2:
interface E1/3
switchport
interface E1/4
switchport
switchport
vpc 10
This logic applies to every VPC.
I used trunk interfaces but you can use access depending on where the VPC are connecting to. Usually trunk between Nexus switches to other Nexus or between Nexus to access switches. When connecting to servers, it depends if servers are using dot1q tags or not.
Hope this will help you start
Francesco
PS: Please don't forget to rate and select as validated answer if this answered your question
For starter, i believe you can go with static routing and it will work the same way as ios
Francesco
11 Replies 11
Francesco Molino
You have only 1 vlan routed by the firewall which means your nexus switches will act as simple L2 switches.
Is it the final design or are seeking to do a new design?
You said you connected them in vss and i believe you meant vpc.
Can you share the topology you have in place because based on what you’re saying the configuration will be very basic.
Francesco
Thansk Francesco for your prompt response .
Here is the design for our nexus switch (yes its simple design) , however it's difficult for me (I am new
to nexus switch :(    )
Waiting for your valuable output .
I’ll prepare some config tomorrow but you’re missing 2 links between the 9300 which would be a full spanning-tree loop free design.
Francesco
Francesco Thanks for the reply again .
Can you please advice regrading the missing link .
BR,Mansour
Sorry I’ll do the config tomorrow, it’s been along day today....
Francesco
No problem, will be waiting for you.
feature lacp
feature vpc
vlan 10
name test-vlan-10
vlan 20
name test-vlan-20
vlan 30
name test-vlan-30
vlan 40
name test-vlan-40
interface mgmt0
vpc domain 1
peer-switch
role priority 20
delay restore 150
peer-gateway
ip arp synchronize
switchport
no shutdown
switchport
no shutdown
switchport
vpc peer-link
int vlan 10
hsrp 10
ip 10.10.10.1
preempt
priority 105
no shut
feature lacp
feature vpc
vlan 10
name test-vlan-10
vlan 20
name test-vlan-20
vlan 30
name test-vlan-30
vlan 40
name test-vlan-40
interface mgmt0
vpc domain 1
peer-switch
role priority 40
delay restore 150
peer-gateway
ip arp synchronize
switchport
no shutdown
switchport
no shutdown
switchport
vpc peer-link
int vlan 100
hsrp 10
ip 10.10.10.1
preempt
no shut
N9K-1:
interface E1/3
switchport
interface E1/4
switchport
switchport
vpc 10
N9K-2:
interface E1/3
switchport
interface E1/4
switchport
switchport
vpc 10
Francesco
Thanks so much Frances.
A great explanatory for someone new to the filed of nexus switches and a great way to start .
For internet connectivity all i have to do is to create layer3 vlan with ip address on the inside interface of the internet and do static route ,Right ?
Thanks so much to put this much time helping who needs your expertise and information .
BR,Mansour
Francesco
it depends on your design. You can use Static Route or BGP.
Thanks Abdulila for your reply seems i will start configuration tomorrow with help of Frances post .
