netflow problems
WFEARLS
We recently installed the Nexus 1000V in our lab ESX cluster.  I'm trying to export netflow data to our collector, but I get errors when I try to add a flow monitor to a port profile or individual interface.  Here's the error we get:
ASB-UPG-VSM01(config-port-prof)# ip flow monitor Monitor-all output
2010 Jul 13 17:27:36 ASB-UPG-VSM01 %NFM-2-VERIFY_FAIL: Verify failed - Client 0xff010266, Reason: unknown error, Interface: Vethernet6
2010 Jul 13 17:27:36 ASB-UPG-VSM01 %NFM-2-VERIFY_FAIL: Verify failed - Client 0xff010266, Reason: unknown error, Interface: Vethernet7
2010 Jul 13 17:27:36 ASB-UPG-VSM01 %NFM-2-VERIFY_FAIL: Verify failed - Client 0xff010266, Reason: unknown error, Interface: Vethernet8
2010 Jul 13 17:27:36 ASB-UPG-VSM01 %NFM-2-VERIFY_FAIL: Verify failed - Client 0xff010266, Reason: unknown error, Interface: Vethernet9
The system message document did not have any helpful info on this error.  Has ayone seen this or had difficulty exporting netflow data?
shaagarw
Sorry for the delayed response. Are you still facing this problem? If yes, can you please attach output of following commands when you see this error:
1. show version
2. show running-config
3. show module
4. show flow internal ddb db
5. vem-support all
Please note first 4 commands need to run on VSM. Last command on the VEM which hosts the trouble creating Vethernet.
-Shachi
