Network connectivity not working (on port-group with LACP)
compassnl
I have this config in my nexus 1000v:
port-profile type vethernet Server-network
  vmware port-group
  switchport mode access
  switchport access vlan 2
  no shutdown
  system vlan 2
  state enabled
port-profile type ethernet Server-uplinks
  vmware port-group
  switchport mode trunk
  switchport trunk allowed vlan 2-1001
  channel-group auto mode active
  no shutdown
  system vlan 2
  state enabled
The server-uplinks port-group got 3 NICs and they are in LACP portchannelgroup on a 3560s stacked switches.
interface Port-channel37
description ESX1
switchport trunk native vlan 999
interface GigabitEthernet1/0/33
description NLAMSESX01-trunk
channel-group 37 mode active
spanning-tree portfast
interface GigabitEthernet2/0/45
spanning-tree portfast trunk
interface GigabitEthernet3/0/33
description NLAMSESX01-trunk *
1. What am i doing wrong? since i cannot get network connectivity trough the (Server-network) NIC...
2. Is the system vlan 2 really neccesary? i dont really understand where that option should be used for, the usage in documentation is very cryptic for me.
Kind regards
Geoffrey
7 Replies 7
lwatta
Geoffrey,
On the VSM does the VEM module show up as connected in "show module"? I'm guessing that your port-channel never really comes up and thats why the traffic never passes.
Can you show us "show module" and "show int brief". We need to make sure the port-channel is really coming up.
Also can you add the following two commands to the interfaces on the catalyst switch
cat65k-1(config)# spanning-tree portfast bpdufilter
cat65k-1(config)# spanning-tree portfast bpduguard
Now a quick primer on system vlans.
The Nexus 1000V is a chassis based virtual switch. You have a supervisor (VSM) and line cards (VEM). In a real switch when a line card is inserted, power-on is detected and the supervisor programs the line card over the backplane. In the Nexus 1000V world the backplane is the network. The line card (VEM) needs the network to be up in order to get programmed, but gets it can't forward traffic until it gets it's programming. So we have a chicken-and-egg type issue. The VEM has a very small configuration that it keeps on the ESX host. When a system vlan is tied to a port-profile, that port-profile is now called a system port-profile and is stored locally on the VEM. When the VEM module loads, it looks at the local configuration and if it has any system port-profiles it starts passing traffic on those port-profiles even if it cannot get programmed.
The following port-profiles should always have system vlans
1. your uplink port - (should carry system vlans for Service Console, VMK, N1KV control and packet)
2. Any port-profile for Service Console
3. Any port-profile carrying a VMK interface
4. Any port-profile carrying the control or packet vlan
Essentially any network interface that truly needs to work even if the VEM and VSM cannot communicate.
louis
I can indeed see that 2 of the 3 ports are in operating mode: down (on the catalyst switches)
Also when i look at the etherchannel trough cisco NA, that the only port that is up, is in standalone mode.
The commands you mention are only for non-trunking ports?? the ports are in trunk mode...
This is the output of show mod:
switch(config)# show mod
Mod  Ports  Module-Type                      Model              Status
1    0      Virtual Supervisor Module        Nexus1000V         active *
3    248    Virtual Ethernet Module          NA                 ok
Mod  Sw               Hw
1    4.0(4)SV1(3a)    0.0
3    4.0(4)SV1(3a)    2.0
Mod  MAC-Address(es)                         Serial-Num
1    00-19-07-6c-5a-a8 to 00-19-07-6c-62-a8  NA
3    02-00-0c-00-03-00 to 02-00-0c-00-03-80  NA
Mod  Server-IP        Server-UUID                           Server-Name
1    10.31.2.240      NA                                    NA
3    10.31.2.10       00000000-0000-435a-4338-303833565758  nlamsesx01
output of show int brief:
Port     VRF          Status IP Address                     Speed    MTU
mgmt0     --           up     10.31.2.240                    1000     1500
Ethernet      VLAN   Type Mode   Status  Reason                   Speed     Port
Interface        Ch #
Eth3/3        1      eth  trunk  up      none                       1000(D) --
Eth3/4        1      eth  trunk  up      none                       1000(D) --
Eth3/5        1      eth  trunk  up      none                       1000(D) --
Eth3/9        1      eth  access up      none                       1000(D) 1
Eth3/10       1      eth  access up      none                       1000(D) 1
Port-channel VLAN  Type Mode   Status  Reason                    Speed  Protocol
Interface
Po1          1     eth  access up      none                      a-1000(D)  none
Po2          1     eth  trunk  link-up No operational members    a-1000(D)  lacp
Interface     VLAN   Type Mode   Status  Reason                   MTU
Veth1         2      virt access up      none                     1500
Veth2         2      virt access up      none                     1500
Veth4         1      virt access up      none                     1500
Veth6         2      virt access up      none                     1500
Veth7         2      virt access up      none                     1500
Veth8         1      virt access up      none                     1500
ctrl0     --           up     --                            1000     1500
2. is very clear, thanks
compassnl
I now have this up and running , after reboot of the ESX server it seems to be working..
But now i have another issue, i also have a iscsi network which have NICs connected to different switches
these catalyst switches do not support etherchannels so i configured it like this:
port-profile type ethernet iSCSI-uplinks
  vmware port-group
  switchport access vlan 1
  pinning id 0
  channel-group auto mode on mac-pinning
  no shutdown
  state enabled
port-profile type vethernet iSCSI-network
  vmware port-group
  pinning id 0
  no shutdown
  state enabled
This configuration does also not seem to work...
Glad you got the other port-channel up.
For your iSCSI config, I suspect a mismatch between your physical network ports and the virtual uplink. How are the physical ports configured on the catalyst for those two nics? Are they trunk or access ports? If they are trunk ports then there is a mismatch.
Also remove the pinning id 0 command under the "ethernet iSCSI-uplinks" port-profile. That command really only works for veth port-profiles.
louis
the Links on the catalyst switches have only VLAN1 configured and are in access mode, so that should be ok.
when i added sub-group-id 0 to the NICs connected to the iscsi switch, Ping to the VM with a NIC connected to the iscsi-network does work.
but a ping (and other connectivity) to other machines from the VM does not work.
Based of what you described there is probably still something wrong with the "Server-uplinks" port-profile.
Are you evaluating the Nexus 1000V or do you have a valid license? If you have a license please open a support call. Opening up a support call at this point will be the fastest way to get resolution to your problem.
If you are evaluating the Nexus 1000V contact me directly and we can setup a webex to try and determine the problem. My email is lwatta@cisco.com.
louis
ok i've send you an email about this... i can say that my first question is resolved so im marking this question as answered and we will continue in the background
