2097
Kris Krogstad
Enthusiast
Nexus 1000v Config for UCS with iSCSI Boot - Help Needed
We have deployed a UCS Domain, with ESX 5.0, Update1, with dual iSCSI Boot NICs to a NetApp Filer.  No issues.  From the ESXi hosts, we can ping and vmkping the iSCSI address.  I added two hosts in Maintenance Mode to the Nexus 1000v.  All communications work as advertised, EXCEPT the iSCSI communication.  Below are my port-profiles. The hosts work fine on iSCSI when moved back to a standard vSwitch.  Also, something interesting is  the iSCSI Path Status shows as not used when looking at the Nexus 1000v iSCSI Initiator settings.  I'm sure it's something stupid, but any help would be great.  I have tickets opened with VMWare and Cisco.
port-profile iSCSI-166
type: Vethernet
description:
status: enabled
max-ports: 32
min-ports: 1
inherit:
config attributes:
  switchport mode access
  switchport access vlan 166
  capability iscsi-multipath
  no shutdown
evaluated config attributes:
  no shutdown
assigned interfaces:
port-group: iSCSI-166
system vlans: 166
capability l3control: no
capability iscsi-multipath: yes
capability vxlan: no
capability l3-vn-service: no
port-profile role: none
port-binding: static
port-profile iSCSI-uplink-166
type: Ethernet
description:
status: enabled
max-ports: 32
min-ports: 1
inherit:
config attributes:
  switchport mode trunk
  switchport trunk allowed vlan 166
  channel-group auto mode on mac-pinning
  no shutdown
  no shutdown
  port-channel6
  port-channel12
  Ethernet3/1
port-group: iSCSI-uplink-166
system vlans: 166
capability iscsi-multipath: no
1 ACCEPTED SOLUTION
Kris Krogstad
Enthusiast
SOLVED:
Inside UCS, all VLANs are trunked and not native, EXCEPT the iSCSI VLAN;
The iSCSI NICs needed to be set as the Native VLAN to allow the hardware to boot from the iSCSI devices, since there was no OS to allow us to assign a specific VLAN until after boot;
Inside the Standard vSwitches that carried the iSCSI traffic, the VLANs were not assigned, since they were the Native VLANs already assigned to the Hardware NICs;
Inside all Cisco Devices, the Native VLAN is always 1, if not specifically assigned inside the Port-Group.  Once we set VLAN 166 to Native on the Uplink Port-Profile, the connectivity commenced.  Originally, the Uplink Port Profile was set the same as all other Uplinks, with a VLAN assigned, but not denoted as “Native”.
port-profile type ethernet iSCSI-uplink-166
  vmware port-group
  switchport trunk native vlan 166
no shutdown
  system vlan 166
  state enabled
2 REPLIES 2
Robert Burns
Kris,
Please private message me the TAC SR # so I can investigate.
Robert
Kris Krogstad
Enthusiast
SOLVED:
  vmware port-group
no shutdown
  system vlan 166
  state enabled
