Highlighted
Beginner
Nexus 1000v L3 mode and native vlan problem
Hello.
Please, help us.
We have some ESXi hosts and VMkernel0 (management) interface of the ESXi hosts in VLAN 521.
VSM in L3 mode and all VSM interfaces in one Port-Profile in VLAN 1.
Uplinks interfaces connected to Nexus 2000, and on both side configured trunks.
If we use trunks on uplink interfaces with native vlan set to 521 on both side (N1K & N2K) then VEM lost connection to VSM.
If we use native vlan other than 521 (vlan where VMK interface of the ESXi hosts reside) then all OK!
Remark: on all switches we use "vlan dot1q tag native"
Why? We need native vlan 521 for ESXi Stateless configuration and PXE boot.
ESXi hosts have IP addresses in VLAN 521 (192.168.6.x/24)
VSM management interface in VLAN 1 (192.168.4.x/24)
Below working configuration. If we changed native vlan to 521 on both switches (N1000v and upstream N2000) then communication VSM-VEM fail.
Config N1K:
vlan dot1Q tag native
svs-domain
  domain id 100
  control vlan 1
  packet vlan 1
  svs mode L3 interface mgmt0
interface mgmt0
  ip address 192.168.4.6/24
port-profile type ethernet Serv-uplinks
  vmware port-group
  switchport mode trunk
  switchport trunk allowed vlan 1,22,340,521,525,1282-1283
  switchport trunk native vlan 340
  channel-group auto mode on
  no shutdown
  system vlan 1,521,525
  state enabled
port-profile type vethernet ESX-vmk-mg
  capability l3control
  vmware port-group
  port-binding static auto
  switchport mode access
  switchport access vlan 521
  no shutdown
  system vlan 521
  max-ports 64
  state enabled
port-profile type vethernet Nexus-VSM-mg
  vmware port-group
  switchport access vlan 1
  no shutdown
  system vlan 1
  max-ports 8
  state enabled
Config N2K:
interface port-channel212
  switchport
  flowcontrol send on
interface Ethernet101/1/10
  switchport
  spanning-tree port type edge trunk
  channel-group 212
  no shutdown
interface Ethernet101/1/11
  switchport
  channel-group 212
  no shutdown
Everyone's tags (5)
Content for Community-Ad
Cisco COVID-19 Survey
