Contributor
Nexus 1000V Switching Problem
Background:
I have two ESXi Servers (10.0.0.14, and 10.0.0.15)
I have a redundant set of Nexus 1000v VSMs, one running on each ESXi server.
I have a vethernet port-profile on vlan 20.
I have a vethernet and an ethernet profile on vlan 201 (each ESXi server had a connection for this vlan to a physical switch)
I have two hosts, one on each ESXi server.
Config:
port-profile type vethernet veth-asaha
vmware port-group
switchport mode access
switchport access vlan 20
no shut
system vlan 20
state enabled
port-profile type vethernet veth-newasaha
vmware port-group
switchport access 201
no shut
system vlan 201
state enabled
port-profile type ethernet eth-newasaha
vmware port-group
switchport access vlan 201
no shut
system vlan 201
state enabled
Question:
When I connect my ASAs or two hosts to the veth-asaha port-profile, they can not ping eachother.
When I connect my ASAs or two hosts to the veth-newasaha port-profile (which has a ethernet port-profile connected to an external switch), they can ping each other just fine.
Does the Nexus 1000v actually do layer 2 switching, or does it require a connection to a physical switch?  If it does do the switching itself, can anyone think of any reason that my hosts would not be able to ping eachother.
Thanks for any help that you can give.
Everyone's tags (7)
