09-02-2016 09:39 AM
I currently setup a Nexus 1000v lab with vCenter and ESXI host. I've added the VSM with 2 VEM's. I am able to reach the management VLAN (VLAN192) and any VM added to that same VLAN, but when I try to add a VM to my VM-Server VLAN (VLAN200), they can't reach anything outside that VLAN. I have one uplink port-profile trunked and allowing both VLAN's through to adjacent 2960 switch, which is also set to trunk and native VLAN192. Both VLAN's are allowed over that trunk. I have two vEthernet port-profiles on the N1K for both VLAN's.
Also, the central switch is running Layer 3 with OSPF and have confirmed that the inter-vlan routing is working properly.
I am sure that something is missing, just not sure what......any assistance would be greatly appreciated!
(attached is the network diagram, n1k configs, and vDS vmnic setup)
Solved! Go to Solution.
09-06-2016 09:15 AM
So it seems I was looking beyond the physical limitations of my ESXi hosts and needed to allow multiple VLAN's through the NIC adapter. Luckily for me this was a quicker fix than I imagined. If you happen to have a supported Intel adapter, go to the link below and use the ANS application.
09-06-2016 09:15 AM
