04-14-2011 11:19 PM
Hello Everyone,
Th Lady Luck got angry with me and I (Firewall Engineer) has been assigned to Upgrade a Critical Cisco Nexus 1000V Cluster with latest 4.2(1)SV1(4)
Here are my Setup Details:-
Current VSM:-
Software
loader: version 1.2(2) [last: image booted through mgmt0]
kickstart: version 4.0(4)SV1(2)
system: version 4.0(4)SV1(2)
Current VEM:-
Mod Sw Hw
1 4.0(4)SV1(2) 0.0
2 4.0(4)SV1(2) 0.0
3 4.0(4)SV1(2) 1.20
4 4.0(4)SV1(2) 1.20
5 4.0(4)SV1(2) 1.20
6 4.0(4)SV1(2) 0.4
7 4.0(4)SV1(2) 0.4
8 4.0(4)SV1(2) 1.20
9 4.0(4)SV1(2) 1.20
10 4.0(4)SV1(2) 1.20
11 4.0(4)SV1(2) 1.20
12 4.0(4)SV1(2) 1.20
13 4.0(4)SV1(2) 0.4
14 4.0(4)SV1(2) 1.20
15 4.0(4)SV1(2) 1.20
16 4.0(4)SV1(2) 1.20
Planned:-
VSM:-4.2(1)SV1(4)
VEM:- 4.2(1)SV1(4)
After Reviewing the Cisco Docs I figured out that the Upgrade Path will me like this :-
1) Upgrade the VSM from 4.0(4)SV1(2) to 4.0(4)SV1(3b)
2)Upgrae the All VEM from 4.0(4)SV1(2) to 4.2(1)SV1(4)
3) Upgrade the VSM from 4.0(4)SV1(3b) to 4.0(4)SV1(4)
For the Step 2 after Refering the Cisco Doc:-
My Server Team told me that VUM is not "working" in our infrastatucture , so we have to upgrade the VEM Manually , but the Cisco Doc shows the Upgrade Method only for Release 4.0(4)SV1(3, 3a, or 3b) to Release 4.2(1)SV1(4) , here mine current version is missing i.e. 4.0(4)SV1(2)
Is it OK if I following the Upgrading the VEMs Manually: Release 4.0(4)SV1(3, 3a, or 3b) to Release 4.2(1)SV1(4) Procedure ???
Also I am confused abt Updating the VEM on the ESX host which are carrying the VSM - most scary ones
also Wht all else things should I make note before the acutal activity , Kindly guide me through...pls
regards
T
04-15-2011 10:07 AM
Hi there,
It looks like a typo in the documentation. I'm following up to confirm this is the case. I'll have an update for you by EOD today.
Sachin
04-15-2011 12:44 PM
It looks like this was missed in the documentation. The link in the screenshot you attached should read:
Upgrading the VEMs Manually: Release 4.0(4)SV1(2, 3, 3a, or 3b) to Release 4.2(1)SV1(4)
I have verified this with one of the VEM upgrade folks locally and am following up with the docs team to get it corrected.
Cheers,
Sachin
