I have a Problem in symmetric hashing on port channel in nexus 3172PQ.
In my design i want to use two Nexus 3172PQ that ether channel together. between these switches, there is a layer 2 devices that capture traffic flow. But when enable port channel on my both switches and set symmetric hash algorithm on global configuration system, Unfortunately forward and reverse traffic flow dose not use the same physical interface.Therefore i can't monitor traffic flow between these switches.
Anybody here known
Why doesn't symmetric algorithm work?As noted in the data sheet, This series supports this feature(symmetric hashing)
What is the problem?
My topology is attached
OS version on both switches: nx-os 7.0(3)i7(1)
