03-26-2019 03:15 AM
did anyone use VXLAN on Nexus 3172PQ? On Cisco compare models it is visible that it supports VXLAN bridging but there is no config guide for VXLAN for this model.
Any advice ?
BR
Vlad
03-26-2019 03:49 AM
03-26-2019 06:17 AM
I use 7.0(3)I7(6).
03-27-2019 10:01 AM
Vlad,
Could this be what you are looking for? https://www.cisco.com/c/en/us/td/docs/switches/datacenter/nexus3000/sw/interfaces/7_x/b_Cisco_Nexus_3000_Series_NX-OS_Interfaces_Configuration_Guide_7x/b_Cisco_Nexus_3000_Series_NX-OS_Interfaces_Configuration_Guide_7x_chapter_0101.html
If you Ctrl+F for "3100" you will see plenty of mention of this specific platform within that configuration guide.
Hope that helps!
03-28-2019 06:01 AM
Thank you for reply Andrea. I got confused because when checking config guide for 3172 model it redirects to 3600 config guide.
hopefully vxlan will work as expected.
BR
Vlad
