Nexus 3172PQ VX-LAN
Vl@d@Ni
did anyone use VXLAN on Nexus 3172PQ? On Cisco compare models it is visible that it supports VXLAN bridging but there is no config guide for VXLAN for this model.
Any advice ?
BR
Vlad
shaps
Level 3
Level 3
What version are using ? the config guides on the 3k platform should show the configuration templates required for your version train.
I use 7.0(3)I7(6).
Andrea Testino
Vlad,
Could this be what you are looking for? https://www.cisco.com/c/en/us/td/docs/switches/datacenter/nexus3000/sw/interfaces/7_x/b_Cisco_Nexus_3000_Series_NX-OS_Interfaces_Configuration_Guide_7x/b_Cisco_Nexus_3000_Series_NX-OS_Interfaces_Configuration_Guide_7x_chapter_0101.html
If you Ctrl+F for "3100" you will see plenty of mention of this specific platform within that configuration guide.
Hope that helps!
- Andrea, CCIE #56739 R&S
Thank you for reply Andrea. I got confused because when checking config guide for 3172 model it redirects to 3600 config guide.
hopefully vxlan will work as expected.
BR
Vlad
