Nexus 3K Upgrade and ISSU
asinghi
Hi Team,
I am upgrading nexus 3k by running install all command and have put "show lacp issu-imapct" as pre-check. The issue is show lacp issu-imapct is giving me some ports which are not issu ready which means I have to either disable lacp fast on the other end or shut down the port before going for upgrade.
What I want to know, if I can remove the command show lacp issu-impact from the upgrade process and run "install all " only to upgrade the switch since 3K doesn't actually supports ISSU in terms of downtime.
#nexus3k #3172 #3048 #issu #ISSU
balaji.bandi
iam not a fan of ISSU, it has some drawbacks i have seen before.
my traditionla way approach below :
1) Save configuration before starting.
2) Check there is enough space on devices
3) Copy over firmware to the bootflash, both kickstart firmware and system files.
copy to disk copy kickstart.bin bootflash:
copy to disk copy orginal.bin bootflash:
install all kickstart kickstart.bin system orginal.bin
4) Once the secondary responds to pings again, logon and check that the secondary nexus has come back up with the right firmware
Checking that vPC (protocol used for the network resilience), is up correctly by doing a show vPC, before upgrading the primary.
5) Repeat process for Primary device
checks
show vPC
show version
BB
