01-12-2020 05:06 AM
Hello
Kindly find attached file.
I have 2 nexus 3k with vpc connected to servers.
When i configure the vpc under port-channel , i can't ping to server.
Appreciate your feedback.
Thank you
01-12-2020 05:34 AM
Can you explain more here? which port-channel is this ? and what physical port the Server connected?
what is the Server (windows ?) side config ? is this LACP ? or Active-Standby?
01-12-2020 05:36 AM
Hello B.B
Port-chanel 75
connected to Hyper-V
01-12-2020 05:55 AM
if you get chance to simulate the issue
can you post
show vpc
show port-channel summary interface port-channel 75
Also, try change from Active to ON (both the nexus and let us know)
channel-group mode on
01-12-2020 06:11 AM
01-12-2020 06:26 AM
Hello B.B
The protocol at VMware LACP
I think i must make port-channel Active
Appreciate your help
01-12-2020 07:33 AM - edited 01-12-2020 07:33 AM
I am confused here or am i reading wrong,
1. First, you mentioned Hyper-V
2. Second, you comment VMWARE? ( do you have vSwitch configured inside VMWARE, is this Exsi or VMWARE Workstation?
Can you explain how is your setup? Physically connected to where?
I have also requested below output from switch. ( i do believe, you lost connection due that Port-channel not come up ?)
show vpc
01-12-2020 10:08 AM
Hello B.B
First,i want to apologize for this case.
Second, the customer moving servers from Hyper-V to VMware.
Third , The Configuration as you want :
For Primary Switch :
B1DC-02A-Upper(config)# show vpc
Legend:
(*) - local vPC is down, forwarding via vPC peer-link
vPC domain id : 1
Peer status : peer adjacency formed ok
vPC keep-alive status : peer is alive
Configuration consistency status : success
Per-vlan consistency status : success
Type-2 consistency status : success
vPC role : primary
Number of vPCs configured : 3
Peer Gateway : Disabled
Dual-active excluded VLANs : -
Graceful Consistency Check : Enabled
Auto-recovery status : Enabled, timer is off.(timeout = 240s)
Delay-restore status : Timer is off.(timeout = 30s)
Delay-restore SVI status : Timer is off.(timeout = 10s)
vPC Peer-link status
id Port Status Active vlans
1 Po999 up 1,32,110,1100-1115
vPC status
id Port Status Consistency Reason Active vlans
70 Po70 up success success 1,32,110,11
00-1115
75 Po75 up success success 1100
888 Po888 down* success success -
B1DC-02A-Upper(config)# show vpc peer-keepalive
--Peer is alive for : (185156) seconds, (68) msec
--Send status : Success
--Last send at : 2020.01.12 12:23:51 696 ms
--Sent on interface : mgmt0
--Receive status : Success
--Last receive at : 2020.01.12 12:23:51 697 ms
--Received on interface : mgmt0
--Last update from peer : (0) seconds, (10) msec
vPC Keep-alive parameters
--Destination : 10.10.10.2
--Keepalive interval : 1000 msec
--Keepalive timeout : 5 seconds
--Keepalive hold timeout : 3 seconds
--Keepalive vrf : management
--Keepalive udp port : 3200
--Keepalive tos : 192
B1DC-02A-Upper(config)# show port-
port-channel port-profile
B1DC-02A-Upper(config)# show port-channel summary
Flags: D - Down P - Up in port-channel (members)
I - Individual H - Hot-standby (LACP only)
s - Suspended r - Module-removed
S - Switched R - Routed
U - Up (port-channel)
p - Up in delay-lacp mode (member)
M - Not in use. Min-links not met
Group Port- Type Protocol Member Ports
Channel
4 Po4(SD) Eth NONE --
13 Po13(SD) Eth NONE --
21 Po21(SD) Eth NONE --
22 Po22(SD) Eth NONE --
23 Po23(SU) Eth LACP Eth1/9(P) Eth1/10(s)
25 Po25(SD) Eth NONE --
26 Po26(SD) Eth NONE --
27 Po27(SD) Eth NONE --
30 Po30(SD) Eth NONE --
31 Po31(SD) Eth NONE --
40 Po40(SD) Eth NONE --
41 Po41(SD) Eth NONE --
46 Po46(SD) Eth LACP Eth1/22(D)
50 Po50(SD) Eth NONE --
52 Po52(SU) Eth LACP Eth1/11(P) Eth1/12(P)
60 Po60(SU) Eth LACP Eth1/16(P) Eth1/17(P)
61 Po61(SU) Eth LACP Eth1/18(P) Eth1/21(D)
70 Po70(SU) Eth NONE Eth1/13(P) Eth1/14(P)
71 Po71(SD) Eth NONE --
75 Po75(SU) Eth LACP Eth1/31(P) Eth1/32(P)
888 Po888(SD) Eth NONE Eth1/53/1(D)
999 Po999(SU) Eth LACP Eth1/49(P) Eth1/50(P)
For Secondary Switch :
B1DC-02B-LOWER(config)# show vpc
Legend:
vPC domain id : 1
vPC role : secondary
vPC status
00-1115
B1DC-02B-LOWER(config)# show vpc peer-keepalive
--Peer is alive for : (1693093) seconds, (645) msec
--Last send at : 2020.01.12 12:25:39 967 ms
--Last receive at : 2020.01.12 12:25:39 968 ms
--Last update from peer : (0) seconds, (6) msec
--Destination : 10.10.10.1
B1DC-02B-LOWER(config)# show port-
B1DC-02B-LOWER(config)# show port-channel summary
Channel
2 Po2(SD) Eth NONE --
3 Po3(SD) Eth NONE --
14 Po14(SD) Eth NONE --
23 Po23(SD) Eth NONE --
32 Po32(SD) Eth LACP Eth1/13(D) Eth1/14(D) Eth1/15(D)
Eth1/16(D)
45 Po45(SU) Eth LACP Eth1/29(P) Eth1/30(P)
46 Po46(SU) Eth LACP Eth1/31(P) Eth1/32(P)
52 Po52(SD) Eth NONE --
60 Po60(SD) Eth NONE --
61 Po61(SD) Eth NONE --
62 Po62(SU) Eth LACP Eth1/37(P) Eth1/38(P)
63 Po63(SU) Eth LACP Eth1/39(P) Eth1/41(D)
70 Po70(SU) Eth NONE Eth1/5(P) Eth1/6(P)
75 Po75(SU) Eth LACP Eth1/20(P) Eth1/21(P)
76 Po76(SD) Eth NONE --
754 Po754(SD) Eth NONE --
Thank you
01-12-2020 11:50 AM
Hello
On the server make sure your teaming is setup correctly that you have the Vnics in the correct vlan that is tagged
01-12-2020 11:58 AM
Hello Paul
yes ,There are teaming on the server configured.
01-12-2020 02:10 PM
Hello
@Mohamed.Ashraf wrote:
Hello Paul
Are they in a tagged vlan such as 1100 ?
01-13-2020 05:30 AM
Looks good to me as per Switch side, so when you enable vPC is the port-channel still up ?
Make sure you have correct setup on vSwitch side.
01-13-2020 05:36 AM
Hello B.B
I want you to know , When i enable the VPC on port-channel i can't access the server althought when i remove VPC from port-channel that make me access the server.
01-13-2020 08:54 AM
HAve you checked on the Server connecting the Console and Monitor, what is the status on Esxi side ?
Can you post you esxi vswitch screen shot to understand better on this issue. we do not see for now any issue on switch side.
