06-13-2022 10:58 PM
I have nexus 5596up with module n55-m160l3, and I'm interesting how can I see how much traffic goes through n55-m160l3? Maybe there is something command for it?
06-14-2022 03:51 AM
Hi @dijix1990
That's the L3 daughter card. I do not have one around to check internal commands, but because only routed traffic is sent to the module, one way to verify the volume of traffic sent to it, is to monitor the statistics of SVIs.
Cheers,
Sergiu
06-14-2022 03:57 AM
06-14-2022 04:09 AM - edited 06-14-2022 04:09 AM
Hi @dijix1990
Try the command:
show interface vlan <id> counters
If it doesn't work, could be possible that you have an old NXOS release. Try an upgrade and very afterwards.
Cheers,
Sergiu
06-14-2022 05:24 AM
06-14-2022 07:56 PM
unfortunately it doesn't work, and i installed last firmware for N5K-C5596UP a long time..
sh int vlan 2198 counters -------------------------------------------------------------------------------- Port InOctets InUcastPkts -------------------------------------------------------------------------------- Vlan2198 0 0 -------------------------------------------------------------------------------- Port InMcastPkts InBcastPkts -------------------------------------------------------------------------------- Vlan2198 0 0 -------------------------------------------------------------------------------- Port OutOctets OutUcastPkts -------------------------------------------------------------------------------- Vlan2198 0 0 -------------------------------------------------------------------------------- Port OutMcastPkts OutBcastPkts -------------------------------------------------------------------------------- Vlan2198 0 0
06-14-2022 10:48 PM
Do you have L3 license installed?
Is there any routed traffic on vlan 2198? Note that ONLY routed traffic is displayed here.
Normally the counters listed in "show interface counters" can be also translated in SNMP counters.
Cheers,
Sergiu
06-14-2022 10:55 PM - edited 06-14-2022 11:02 PM
of course, we use nexus as L3 core (Release 7.3(8)N1(1)
sh feature | i ena dhcp 1 enabled fex 1 enabled hsrp_engine 1 enabled interface-vlan 1 enabled lacp 1 enabled lldp 1 enabled ospf 1 enabled pbr 1 enabled private-vlan 1 enabled sshServer 1 enabled vpc 1 enabled
sh license | i LAN INCREMENT LAN_ENTERPRISE_SERVICES_PKG cisco 1.0 permanent uncounted \ INCREMENT LAN_BASE_SERVICES_PKG cisco 1.0 permanent uncounted \
06-14-2022 11:26 PM
Do you see the same results on all SVIs with the command "show interface counters | grep Vlan"?
06-14-2022 11:29 PM
yes the same results for all SVIs, I think it maybe a bug, I'm going to try new firmware 7.3(11)N1(1)
06-15-2022 01:00 AM
Yep, better check the newest firmware. Let us know the results after the upgrade.
Take care,
Sergiu
06-14-2022 11:27 PM
Can you also check this command:
show interface counters detailed snmp
Cheers,
Sergiu
06-14-2022 11:49 PM
yes, I did it too, counters are zero
