muhammednikhilmm
Beginner
nexus 5k port speed issue to set 100 mb
Any one can help me: how can i set speed 100 MB on nexus 5k - GLC-T SFP port.
while i try to set the port speed to 100 i am getting error like below.
ERROR: Ethernet1/26: Configuration does not match the port capability.
any one can help me to fix this issue.
3 REPLIES 3
nazimkha
Enthusiast
Which model of Nexus 5K do you have ?
AFAIK, Nexus 5K does not support 100Mb you have to use a FEX or a other switch
Yes, you are correct but i was looking for any workaround method to fix this. any way currently i connected the device to our 2k and solved for now. The strange thing is that the 3k support 100 mb but not 5k.
any way thanks for the comment Mr. Nazimkha.
I think they specked out the N5K for only specific purpose and believed that FEX will serve as the TOR.
Please mark the post as resolved if you think your query has been answered
Content for Community-Ad
