Highlighted
Beginner
Nexus 7000 series - Fan Speed
1. How we can check the fan speed of the Cisco Nexus 7000 series or how we can change the fan speed ?
2. what is the purpose of using  hardware fan-tray maintenance-mode command ?
1 ACCEPTED SOLUTION
Highlighted
Collaborator
Hi @SMK91
You cannot change the speed of fans on neither of the Nexus platforms. The speed is adjusted based on the system temperature/version/platform.
You can however check the fan speed (in percentage) using:
N7K-1# show environment fan
Fan:
Fan             Model                Hw         Status
Fan1(sys_fan1)  N77-C7706-FAN        1.2        Ok
Fan2(sys_fan2)  N77-C7706-FAN        1.2        Ok
Fan3(sys_fan3)  N77-C7706-FAN        1.2        Ok
Fan_in_PS1      --                   --         Ok
Fan_in_PS2      --                   --         Absent
Fan_in_PS3      --                   --         Ok
Fan_in_PS4      --                   --         Absent
Fan Zone Speed %(Hex): Zone 1: 41.18(0x69)
2. hardware fan-tray maintenance-mode has the role to cool off the system before a fan tray replacement/removal.
To put the switch in fan tray maintenance mode to prepare the switch for fan tray migration or removal,
use the hardware fan-tray maintenance-mode command. To disable fan tray maintenance mode, use the no form of this command. hardware fan-tray maintenance-mode [long | medium | short] no hardware fan-tray maintenance-mode [long | medium | short]
long
(Optional) The fans run at 65% speed for approximately 9 minutes.
medium
(Optional) The fans run at 75% speed for approximately 6 minutes.
short
(Optional) The fans run at 85% speed for approximately 4 minutes.
Reference: https://www.cisco.com/c/en/us/td/docs/switches/datacenter/nexus7000/sw/system-management/command/reference/n7k_sm_cmd_ref/sm_cmd_h.html
Hope it helps,
Sergiu
1 REPLY 1
Highlighted
Collaborator
Hi @SMK91
Fan:
Fan             Model                Hw         Status
Fan_in_PS1      --                   --         Ok
Fan_in_PS3      --                   --         Ok
long
medium
short
Hope it helps,
Sergiu
