Highlighted
Enthusiast
Nexus 7004 - copy from HTTPS source
Is there a way to copy a file or text from an HTTPS source? When I do "copy ?", I only see http, not https... Is there a feature that needs to be enabled? Thanks.
2 REPLIES 2
Highlighted
VIP Mentor
Re: Nexus 7004 - copy from HTTPS source
copy a file or text from an HTTPS source  - BB  - you can copy from https source, as long as path is correct
what are you trying to achieve here? can you post- show version.
i do see https on nexus os here.
switch# copy ?
bootflash: Select source filesystem
core: Select source filesystem
debug: Select source filesystem
ftp: Select source filesystem
http: Select source filesystem
https: Select source filesystem
licenses Backup license files
log: Select source filesystem
logflash: Select source filesystem
nvram: Select source filesystem
running-config Copy running configuration to destination
scp: Select source filesystem
sftp: Select source filesystem
startup-config Copy startup configuration to destination
switch-profile-cfg Copy switch profile running configuration to destination
system: Select source filesystem
tftp: Select source filesystem
usb1: Select source filesystem
usb2: Select source filesystem
volatile: Select source filesystem
BB
*** Rate All Helpful Responses ***
Highlighted
Enthusiast
Hi Balaji, here is my show ver output. I have also opened up a ticket and they told me that it is not supported... What version are you running on? Is it also the 7004 platform? I am wondering if it is platform relevant. Thanks.
Cisco Nexus Operating System (NX-OS) Software
TAC support: http://www.cisco.com/tac
Documents: http://www.cisco.com/en/US/products/ps9372/tsd_products_support_series_home.html
Copyright (c) 2002-2017, Cisco Systems, Inc. All rights reserved.
The copyrights to certain works contained in this software are
owned by other third parties and used and distributed under
license. Certain components of this software are licensed under
the GNU General Public License (GPL) version 2.0 or the GNU
Lesser General Public License (LGPL) Version 2.1. A copy of each
such license is available at
http://www.opensource.org/licenses/gpl-2.0.php and
http://www.opensource.org/licenses/lgpl-2.1.php
Software
  BIOS:      version 2.12.0
  kickstart: version 6.2(18)
  system:    version 6.2(18)
  BIOS compile time:       05/29/2013
  kickstart image file is: bootflash:///n7000-s2-kickstart.6.2.18.bin
  kickstart compile time:  2/27/2017 9:00:00 [02/17/2017 03:48:44]
  system image file is:    bootflash:///n7000-s2-dk9.6.2.18.bin
  system compile time:     2/27/2017 9:00:00 [02/17/2017 05:30:05]
Hardware
  cisco Nexus7000 C7004 (4 Slot) Chassis ("Supervisor Module-2")
  Intel(R) Xeon(R) CPU         with 32745060 kB of memory.
  Processor Board ID JAF1815ACHR
  Device name: QA-ADM01-00RM255R3R3
  bootflash:    2007040 kB
  slot0:              0 kB (expansion flash)
Kernel uptime is 821 day(s), 22 hour(s), 26 minute(s), 39 second(s)
Last reset
  Reason: Unknown
  System version: 6.2(18)
  Service:
plugin
  Core Plugin, Ethernet Plugin
Content for Community-Ad
Cisco COVID-19 Survey
