10-22-2018 06:46 AM
Hi ,
OSPF totaly stub area on nexus 7706 dont want to announce default route on interface vlan.
Only when i 3 times reset ospf process or only when delete inteface vlan and add it again it starts announce default route.
Only after that it start to show in ospf database and it announce def. route.
Sw version 8.3.1
NX7K-CoreNW# show ip ospf corenw database vrf test
OSPF Router with ID (x,x.x.x) (Process ID corenw VRF test)
Network Link States (Area 0.0.0.1)
Link ID ADV Router Age Seq# Checksum
Anyone had same problem?
Cheers
VZ
10-23-2018 05:10 AM
Hi there,
Can you share the following (change X for the SVI you mentioned you delete/add):
show run ospf show run int vlan X << where X is the SVI you mentioned show run vrf test
show accounting log | i i ospf|vlan.X << Change X for the SVI you mentioned
show cores
show system internal mts buff summary
show system reset-reason
Is this something you can reproduce consistently or it just happened this one time?
10-30-2018 07:43 PM
Specify the source interface for informs and traps if the management VRF instance is not being used. This allows security devices such as firewalls to identify the source of the SNMP packet. If the source interface or IP address is not specified the primary IP address on the originating (outbound) interface is selected. The inform feature only applies to SNMP v2c and v3. You can configure the source interface globally for all SNMP hosts or per SNMP host.
Global Configuration:
n7000(config)# snmp source-interface informs loopback0
n7000(config)# snmp source-interface traps loopback0
Per Server Configuration:
n7000(config)# snmp-server host a.a.a.a source-interface loopback0
